Author Topic: What have you done to your Golf today?  (Read 1111614 times)
Offline Mr_Orange
Re: What have you done to your Golf today?
« Reply #1720 on: 24 January 2010, 12:41 »
The sun's out so gave it a proper good wash down.  Got that nasty grit and crap all off!  Same again next weekend but with some heavy waxing.  Might even invest in a clay bar.
Stripped out the rear seats, shelf and trim to try and pin-down an annoying creak, to find that had solved it.  Slowly putting it all back together to find the culprit creaker!   :laugh:
Build thread clicky
Offline Andy-H
« Reply #1721 on: 24 January 2010, 12:45 »
Topped up the screenwash and checked the tyre pressures  :smiley:
'02 A4 Quattro sport - gone
'91 Tornado red Mk2
Offline Horney
« Reply #1722 on: 24 January 2010, 15:11 »
Took it for half an hour and cained the crap out of it. I'm still grinning :grin:
Nick
Offline madgti
« Reply #1723 on: 24 January 2010, 15:28 »
plugs /leads , oil change
Offline Neo Badness
  • Feet are for pedals
« Reply #1724 on: 24 January 2010, 15:53 »
Started it after it sitting the carpark for about 2 months, will need TLC ( truck loads of cash) most likely, but it was running and doesn't seem to have spat it's core plugs in the freeze :shocked:
Has a nocking sound underneath now but it's either exhaust, new shock or a binding rear caliper. Will find out when I get it in the garage...
But it started so it's a step in the right direction.
Offline VR6_ROB
  • Mk2 VR6 / Corrado G60
« Reply #1725 on: 24 January 2010, 16:10 »
did a couple of brake pipes on the golf
then did a pair of ball joints on the audi
and put some repair bandage on the exhaust
stripped the rear brakes and greased them mot has ran out
hopefully should pass tomorrow
Offline Rhyso
« Reply #1726 on: 24 January 2010, 17:38 »
last two days I've mainly done the following
LED rear number plate lights
Fitted push fittings to the rear mats
Hoovered the interior
Wired up my auto dimming mirror
Installed some LED puddle lights
Offline Reasty
  • Alpine white valver.
« Reply #1727 on: 24 January 2010, 18:32 »
Started it up and pulled her out the garage for the first time in 3 months,sulked abit but after I got her warmed up everything was sweeeet! then gave it a goood clean treated the leather then put her back in the garage  :grin: then realised the mot is due next month and it's only done 340 miles since theast one  :laugh:
Offline Khare
  • The bear that khares
« Reply #1728 on: 24 January 2010, 18:36 »
cleaned out the washer jets, hoovered it, sorted the alignment on the full beam, tightened up the PAS belt and topped up fluids.
Offline luke
  • When in doubt, whip it out!
« Reply #1729 on: 24 January 2010, 18:42 »
looked on ebay, seen some nice mk2 alloys, bought them for my dads mk3, now he's thinking of doing a 2.0 16v engine swap
1985 mk2 gti type 19 8v
2018 t roc sel 1.6tdi
