Author Topic: Feeling Flat  (Read 1642 times)
Offline rob026
  • Mk3 16v GTI
Feeling Flat
« on: 03 April 2009, 11:41 »
I have mk3 16v abf, lately when I give it a bit of welly at around 3500 - 4000 rpm it feels hesitant almost like ive got a car full of people, normally at this rpm it would fly off, am i just in need of a tune up or is it something else :sad:
Offline Len
Re: Feeling Flat
« Reply #1 on: 03 April 2009, 11:51 »
Check ECU relay.
www.sas.org.uk
www.the-ace.org.uk
Offline rob026
  • Mk3 16v GTI
Re: Feeling Flat
« Reply #2 on: 03 April 2009, 12:02 »
not wanting to soud stupid but which one is it   :rolleyes:
Offline Len
Re: Feeling Flat
« Reply #3 on: 03 April 2009, 12:48 »
E30 or just 30.
Just in case the relays are situated in the fuse box above the fuses. And fusebox is in front of your right knee when driving!
www.sas.org.uk
www.the-ace.org.uk
Offline rob026
  • Mk3 16v GTI
Re: Feeling Flat
« Reply #4 on: 03 April 2009, 14:04 »
thanks for the info buddy will have a look later when the misses brings the car home :smiley:
Offline GOLF_MK
Re: Feeling Flat
« Reply #5 on: 03 April 2009, 14:24 »
Buy an 8v and you won't have to rev it that far  :grin:
runs and hides................
Offline DazVR6
  • mk3 VR6...FEEL THE GRUNT.
Re: Feeling Flat
« Reply #6 on: 03 April 2009, 14:32 »
Or maybe you meant to say buy an 8v cause you won't be ABLE to rev it that far.... :evil:
Offline rob026
  • Mk3 16v GTI
Re: Feeling Flat
« Reply #7 on: 03 April 2009, 14:36 »
Sounds like a comment from an 8v owner, cos he ran to hide cos its quicker than getting in his car  :grin:
Offline mrpatterson2008
Re: Feeling Flat
« Reply #8 on: 03 April 2009, 16:20 »
Clean you mass air meter, sensor element should be silver not black with dirt
Offline davero
Re: Feeling Flat
« Reply #9 on: 03 April 2009, 17:42 »
There is no air mass meter in a 16v, check all your vacuum pipes, especially the one going from the throttle
body to the ecu(this is your air mass meter on a 16v(map sensor)). And give your throttle body a good clean.
Does it smell of petrol? Is the fuel economy down?
« Last Edit: 04 April 2009, 02:02 by dave16v »
