Author Topic: Ignition timing settings  (Read 3613 times)
Offline samthejazzman
« on: 03 July 2003, 18:59 »
Hello! Could anyone tell me the ignition timing settings for a Mark 2 Golf Driver 1.6 Greg 5 gears.
selling it soon and would like to set the timing right, cannot be buying a Haynes manual for a ten minute use so looking for the angle before tdc at wich to set the timing
please send replies to sboudria@yahoo.co.uk or to 07751231937
Thanking you for your help
Sam
Offline richandhazel
Re:Ignition timing settings
« Reply #1 on: 04 July 2003, 11:56 »
My Haynes only covers 1984 to 1988. The ignition timing for the 1.6 litre carburettor engine is: 17 to 19 deg BTDC.
If you're running on unleaded you may find it will pink in which case you will need to retard the ignition a little.
« Last Edit: 04 July 2003, 11:57 by richandhazel »
