Author Topic: Window Dropped  (Read 1681 times)
Offline Max GTI
Window Dropped
« on: 02 April 2009, 12:06 »
Hello Guys
I just wanted to know how you can tell if your window has "dropped". As my drivers side one makes a rattling sound if you drive over slight bumps/holes if the window is down, if the window is up its fine I guess cause the window is sort of held in place. If the windows is say half way down I have grab the top of the windows and their is some play in it. (I can move it slightly left and right) Do I need to replace a part of the windows inside the door so its more secure.
Thanks in advance
Max
25th Anniversary
No. 1117
Offline jake
Re: Window Dropped
« Reply #1 on: 02 April 2009, 12:40 »
youll know when its dropped when its like mine at the moment lol
mine is able to go down about 3 inches, then gets stuck, then when you try and put it down further it just drops right down to inside the door! :angry: :angry:
so you then have to get out the car looking uber cool and pull the frigin thing up with your hands!! :angry:
so you sound ok for now :grin:
Offline K666PDP
Re: Window Dropped
« Reply #2 on: 02 April 2009, 12:43 »
sounds ok to me mate maybe take the door panel of to have a look and see if u can see anything amiss
Offline Max GTI
Re: Window Dropped
« Reply #3 on: 02 April 2009, 12:45 »
Ok cheers guys il have a look.
25th Anniversary
No. 1117
Offline Rhyso
Re: Window Dropped
« Reply #4 on: 02 April 2009, 12:51 »
yep whip off the door panel and you'll find 2 rubber grommets - lower the window down (you'll have to re-attach the window controls) until you can see the clips through the inspection grommet
if you can see them cracked or missing then get the repair kit :afro:
Offline Max GTI
Re: Window Dropped
« Reply #5 on: 02 April 2009, 13:07 »
Cheers Rhyso
I just found a how to guide so il take a look at that when I get home from work, and il look at the window tomorrow or at the weekend
25th Anniversary
No. 1117
Offline andc1
Re: Window Dropped
« Reply #6 on: 02 April 2009, 19:14 »
sounds like the plastic clips have broken, very common, metal ones are avalable at vw
