Author Topic: Still bugging the hell outta me!!!  (Read 1616 times)
Offline Phil.O
« on: 02 April 2009, 10:21 »
a little while ago when i had the front tyres changed the car seemed to pull a little to the left,
i'm guessing it'd done that for a while and i just didn't have enough tread to notice..... :huh:
after putting the S3 braces on yesterday i swapped the wheels around just incase it was something to do with the
way the new tyres had been fitted / balanced or something random like that but still there,
started really worrying about it today until i realised every road i drove down had a nasty camber on......
found a flat bit of road and seems fine going straight until i accelerate at all then it pulls to the left......
anyone any ideas?!?
a work in progress......someday i might think i'm happy with a car....maybe
so far: 40mm Gmax lowering kit, upper and lower S3 strut braces, pipercross panel filter, Smoothed air box and 18" Audi R8 reps
Offline mason21k
Re: Still bugging the hell outta me!!!
« Reply #1 on: 02 April 2009, 10:25 »
cud be ur tracking
Offline Phil.O
« Reply #2 on: 02 April 2009, 10:26 »
i had the tracking checked loads at the time as i knew a guy with a GTi at a garage near me,
was fine everytime - even had it up on some ramps to try a different way.......
and with tracking i thought it would always pull not just under acceleration?
Offline Rhyso
« Reply #3 on: 02 April 2009, 10:40 »
pressures the same in both tyres??
track rod end? worn bushes??  :undecided:
Offline Phil.O
« Reply #4 on: 02 April 2009, 10:43 »
tyre pressures are the same,
which bushes would effect it? how would i check? - replaced most of them a little while ago
why would a track rod end effect it only when accelerating - i thought that would be the same as tracking - all or nothing?
Offline Rhyso
« Reply #5 on: 02 April 2009, 10:48 »
wishbone bushes  :undecided:
have you checked the dogbone mount??
i'm just throwing ideas around really to ascertain what you've checked / replaced
Offline Phil.O
« Reply #6 on: 02 April 2009, 10:53 »
both wish bones were replaced about a year ago after a little mis-hap when fitting my lowering kit,
i haven't fully check the dog-bone mount but looked ok when i put the lower brace on yesterday
