Author Topic: might have major prob  (Read 4580 times)
Offline (shakey)
  • IS STILL SICK ABOUT CRASHING ME 1.8T AFTER 2 YEARS
« on: 01 April 2009, 22:01 »
right i serviced the car just under 2 wks ago i put 4.5 ltrs in and it was on the max on the dip stick,
went to the rr day and santa pod on wkend check me oil today and it was just showing on the stick so i am hoping its not the rings plus it does smell like its burning oil. :sad:
Offline richw911
Re: might have major prob
« Reply #1 on: 01 April 2009, 22:07 »
Turbo.......
Offline Miggie
  • Golf I II III IV and perhaps V soon
« Reply #2 on: 01 April 2009, 22:09 »
Hello mate,
Not to change the subject but apparently you and i have the same issue re the boost on our cars
Just wanted to know what exactly your car is doing?
Was at R-tech today....and mine is spiking to 14psi and holding it....still pulls hard but does not want to spike to 18-19psi and hold at 14 psi
Is this your issue.....and what have you tried so far?
R-tech Agu k03s power!!
Offline (shakey)
« Reply #3 on: 01 April 2009, 22:13 »
Hello mate,
yes it is the same i have took the intercool off cleaned it cleaned the turbo intake pipe check all the hoses serviced it just waiting for a dv to arrive than try that if that does work then fook nows m8.
Offline (shakey)
« Reply #4 on: 01 April 2009, 22:14 »
Turbo.......
it pulls like hell tho rich.
Offline richw911
« Reply #5 on: 01 April 2009, 22:18 »
Turbo.......
Could be losing oil tho  :undecided:
Offline (shakey)
« Reply #6 on: 01 April 2009, 22:20 »
Turbo.......
o rite will have a look at that then.
Offline Miggie
« Reply #7 on: 01 April 2009, 22:21 »
Same here my car pulls very nicely...just not hitting the 18psi.....
I totally thrashed a 1.8t Ibiza (std), but just about passed a mk5 tdi in 4th
I'm def gonna go up to R-tech again when the roller are ready!
Offline (shakey)
« Reply #8 on: 01 April 2009, 22:27 »
so you have a forge dv on and it is still the same as mine have you got the yellow spring in ur dv.
yea mine goes like hell but if the boost prob is sorted out it will be even better  :grin:
Offline Miggie
« Reply #9 on: 01 April 2009, 22:32 »
Yeah i only saw the spring today for the 1st time when Nick removed it.....
Mine is spiking to 14-15psi and holding it through the rev range....how about yours?
Apparently it's suppose to go passed that and then settle at 14-15psi.
Also Nick removed the actuator pipe (unlimited boost) and it still boosted exactly the same as if it were connected :sad:
