Author Topic: 2e Bottom end, with PAS........?  (Read 1212 times)
Offline Llewellyn
« on: 01 April 2009, 13:21 »
Have read loads about the loom wiring for ABF conversions and see that it is a possibility, and 150bhp out of the box is nice.
I assume putting a 2L bottom end on will give me very little power increase but a wedge of torque?
What cambelt to i need?
my car has power steering also, is this a problem?
cheers
J
« Last Edit: 01 April 2009, 15:00 by Llewellyn »
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline danny_p
Re: 2e Bottom end, with PAS........?
« Reply #1 on: 01 April 2009, 20:55 »
pas is no problem.
use the 2L cambelt
2ltr on 8 valve give bit more power but real gain is  more torque
all the VW's have gone bar 1.
Offline Llewellyn
« Reply #2 on: 01 April 2009, 22:05 »
and is the 2e the only engine that pops straight on and i can use that dizzi, or are there other engine codes that i could use?
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline Diamond Hell
  • Opinions я Us
« Reply #3 on: 01 April 2009, 23:07 »
2E has the right dizzi IIRC, but an AGG has a crank position sensor on it and is younger.  This means you can run fandango management, if you want.
Offline Llewellyn
« Reply #4 on: 02 April 2009, 08:40 »
Advantage to running newer management?
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline nealey
« Reply #5 on: 02 April 2009, 18:21 »
Aftermarket management is easily mapped to suit mods and can be more individually tuned to your car to for greater gains
