Author Topic: VW Fault Code 17916  (Read 4212 times)
Offline tariqb
VW Fault Code 17916
« on: 01 April 2009, 03:30 »
I have the following code come up on the code reader:
17916 -Idle System Learned Value- Upper limit reached (P1508)
What does this mean - where is the problem and what needs replacing?
This fault may explain why my economy levels are so low. Any advice would be appreciated.
Offline Rhyso
Offline tariqb
Re: VW Fault Code 17916
« Reply #2 on: 03 April 2009, 00:20 »
still a little confused as to what would need replacing - air intake? - well that could be the MAF or the Intake manifold or another 1000 things!! can any oneone make this make sense.
Offline Rhyso
« Reply #3 on: 03 April 2009, 07:50 »
or it could be the air intake behind the passenger headlight or it could be the filter............
i'd start at the front of the air intake system and work backwards.............
Offline dai-cymru
  • 1989 MK2 16V
« Reply #4 on: 03 April 2009, 17:46 »
yeah as rhyso says start from behind the headlight, should be quite easy to fix, wouls suspect the air filter itself clogged up
Offline tariqb
« Reply #5 on: 03 April 2009, 21:32 »
just got it serviced last week - new air filter was put in as well as the usual stuff - pollen filter etc  - tips on how to do it would be fab-
