Author Topic: BIG PROBLEMS ?? ANYONE KNOW.  (Read 2753 times)
Offline GolfDan
Re: BIG PROBLEMS ?? ANYONE KNOW.
« Reply #10 on: 01 April 2009, 00:46 »
You won't be driving it till you get it checked out mate you will do the head if you do
Offline Amzy-Bear
« Reply #11 on: 01 April 2009, 00:51 »
Yh i know its gunn ahave to be fixed up there for no more than 100.
or it will cost me about 200 to get it just towed down south. :(
Thanks 4 ur help Golfdan.
ill get them bits checked & maybe changed.
Cheers dude.
:D
Offline scotty iom
« Reply #12 on: 01 April 2009, 01:12 »
sounds like stat to me .. you can get the head gasket checked using a cylinder block crack testing kit,
dead easy check and any garage worth there while should have one...
Offline krave
« Reply #13 on: 01 April 2009, 01:17 »
Im just outside of north london, If your car is localish, I cant promise I can fix it, but for petrol im willing to come and have a look. Look over your pipes, check your stat and pump, and worse case do a compression test.
Offline Amzy-Bear
« Reply #14 on: 02 April 2009, 17:05 »
cheers guys,
yh looks like its a thermo stat,
cheers Krave but its getting sorted out !!
and its in Hayes so not tooo far.
:D
Offline Amzy-Bear
« Reply #15 on: 06 April 2009, 16:57 »
turns out it was the thermo stat.
its all fixed now.
thanks for the help guys.
:D
