Author Topic: replacing wheel bearing  (Read 1458 times)
Offline hyland770
  • Vw Golf 1.6 estimated to have around 500+ bhp
« on: 31 March 2009, 21:33 »
must have been asked a million times but.....
can someone put up a quick step by step guide or similar on how to change a front wheel bearing, i got the haynes manual bt im pretty sure there making it way more complicated than it needs to be!  :undecided:
Offline hyland770
Re: replacing wheel bearing
« Reply #1 on: 31 March 2009, 21:54 »
c'mon one of you has got to have done this!!! dont make me resort to paying for it to be done!!!
Offline boneybradley
  • Back in a Mk3...
« Reply #2 on: 31 March 2009, 21:58 »
you need to remove the hub and pull the old bearing off with a hub puller ideally! I would advise using a press to refit the bearing but people do use sockets etc and tap them on (Its easy to damage the hub!! so you need to be carefull!)
Offline hyland770
« Reply #3 on: 31 March 2009, 22:02 »
cheers for that, i had a quick go at doing it today but found the 2 bolts holding the caliper on wouldnt budge even tried gently hitting the spanner with a hammer and still nothing, and i need to get the whole caliper off so that i can get the disk off to remover the hub assembly! any ideas?
Offline Paul86S2
« Reply #4 on: 31 March 2009, 22:07 »
Usually very tight, use a socket and some kind of extension, scaffolding bar etc to go over the handle.
Paul
  • Back in a Mk3...
« Reply #5 on: 31 March 2009, 22:08 »
or an air gun.... nip to a friendly garage and they will undo the bolts for a couple of quid
Offline MrClifford
  • mk3 golf GTi 8v
« Reply #6 on: 02 April 2009, 04:32 »
http://www.golfgtiforum.co.uk/index.php?topic=8438.0
they are a bugger to get off. me n my mate used a hexagon socket to get them off, carefully tapped them on, the one came off it about 10mins but the other took about 40mins :P just chew the balls outa the old ones to get them off. obviously the bolts were so mullered after we had to use new bolts, and tapped new threads in just to make sure (for the next time they need changing). no worries about heating them up, just tap the hexagon sockets on very carefully and take ur time to get them on just right, then give um a good tug with the socket!if they dont come loose or the socket slips try and try again and it will come off eventualy! also a good idea to undo the shock of the suspension and bracket that holds the pipes for the brakes so u can get a good bit of space to tap on the socket.
when changing the bearing just use a flathead screwdriver and a hammer to very lightly tap out the old bearing and all its components (ideal if there are 2 of u) take ur time aswell tapping them out so u dont spoil the hub. when it comes to putting the new bearing kit in a big socket with gental taps(again so u dont spoil the hub) will only take about 5mins to do, grease it all up, replace the hub, caliper etc and ur ready to rock!
There should now be no biting or anything from the bearings, and if (doesnt usualy happen) when braking with no hands on the wheel u travel to 1 side, bleed and change the fluids of ur brakes and all should b fine and dandy!
coming soon ;)
