Author Topic: engine problem  (Read 820 times)
Offline oliver07
  • golf gti T 200BHP
engine problem
« on: 31 March 2009, 19:12 »
Hi my vr6 obd2 has an engine problem seems to be coming from the top and really noisy any ideas ie piston nor cam sorry im no mechanic
uses no water or oil no smoke dont drive it at the moment because of all the noise :sick:
Offline Adam
Re: engine problem
« Reply #1 on: 31 March 2009, 19:15 »
you have checked the oil right, when was the last time it was changed?
Did it suddenly happen or did it gradually happen?
Down Hill From Here.
Offline oliver07
  • golf gti T 200BHP
Re: engine problem
« Reply #2 on: 31 March 2009, 19:18 »
really not sure just bought it but the oil is on the max and its very clean all i know is it wasnt making the noise when i bought it only after the first 20 miles  :embarassed:
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
Re: engine problem
« Reply #3 on: 01 April 2009, 13:26 »
These engines are chain driven camshafts, the chains are supposed to last for ever.. .but they dont!  if its a rattly/tappy noise comming from the chain side it could well be the problem,  good news is, if its just that, the engine is fine and it will just need changing,  bad news is changing it is realisticly an engine out jobby..  unless you know some one who enjoys getting frustrated in a very small fiddly space, either way i know its the best parts of £800 to change it with the correct tools etc..  can be done DIY though.
Other problems that cause top end noise on them are the hydraluic lifters, usualy make a tapping sound, its not that unusual for one to block up with a bit of sludge and cause it to fail, or even for one to collapse and fail totally.
Another thing that comes to mind, if its knocking from deep with in... gets worse on acceleration and usualy goes on deccleration.. it could be piston slap, its quite normal if that is the case and it shouldnt cause any problems untill its unbearably loud.
Mabey you could post a video recording of the noise...  its a bit easier to tell, even water pump bearings can make nasty noises!
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
