Author Topic: Mk2 GTI 16v KR Downpipe Silencer - what can I replace it with?  (Read 3923 times)
Offline Jameslloydrichards
  • Golf Mk2 GTI 16v OAK GREEN 5 DR
Right,
So I've replaced the exhaust system on my j-plate valver. with a Jetex stainless steel system which is great  :smiley:
However the silencer on the downpipe to which the Jetex is connected to is corroded, badly :sad: and a replacement I've been told will cost an arm and a leg, not good!
I've got a question, do I need this silencer, is there a straight through connector I can get from Manifold to the Jetex and would that make it really loud? Are Stainless Steel replacements made for that part at all?  I'd rather not buy a mild steel part and have to replace that  in a couple of years at £150 a go.
Any advice most welcome, I'm guessing a straight through pipe from the manifold to the exhaust might be the best thing.  I live in a residential area and the Jetex, plus the blown manifold silencer is about on the limit of acceptable noise! LOL!
My golf is the best car I've ever owned!
this box is just a resonator rather than a silencer, so removing it wont make much difference to the exhaust note. if you can find one a g60 downpipe and cat-bypass is a direct swap for the 16v downpipe, though you have a fun time in store for you removing that downpipe!
Thank you!
Well I'm happy to take on the task of getting the G60 downpipe on, if I can find one but I'm on the case. One final question though, if I can't find said bit. Is there an alternative I can use, or perhaps can I buy a G60 downpipe, prob a silly question! :smiley: But I'd rather not buy a new 16v downpipe, especially as the resonator doesn't actually kill any noise.
Thanks, once again rubberjohnny
Apparently MK3 ones also work, but I cant say for sure as I'm not 100% what the bore is on them. that being said if you get just the downpipe a decent zaust place should be able to knock up a section of straight pipe to go between it and the front silencer :)
Corrado 16v 9a one is also probably a close match if not direct fit :)
Offline GLC GTI
Just fount this thread after a quick search.
Mine is blowing bad and I'm finding it hard to get a replacement, after reading this I'm just going to get it cut out and replaced with a bit of pipe.
Offline Lewy
Offline JC
  • Back in the North.
bored lewy  :grin:
Offline GLC GTI
Found this last night
http://cgi.ebay.co.uk/VW-GOLF-1-8i-16v-Mk-2-GTi-CAT-FRONT-PIPE_W0QQitemZ130286752226QQcmdZViewItemQQptZUK_CarsParts_Vehicles_CarParts_SM?hash=item1e55b211e2&_trksid=p3286.c0.m14&_trkparms=65%3A12|66%3A2|39%3A1|72%3A1689|240%3A1318|301%3A0|293%3A1|294%3A50
anyone know the best place mail order to get a bit of pipe to mate up to the exhaust?
i got these on my watch list:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=230344226224
http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&item=220413275960
1st one is handy since it has 2 lambda bungs, can use one for your managemwent and another for a gauge
Offline Reasty
  • Alpine white valver.
my 16v has a 4 branch manifold and my local exhaust garage made a pipe to replace the front box (mine has no cat) you can also get a pipe from vollksbits.co.uk that replaces the centre box so just leaving your backbox as the only box in the system.
Trust me this is the set up i have and it sounds awesome quite loud, but not like a cheap sound you hear on certain boy racer cars but
more of a means business roar!
