Author Topic: my rev counter stopped workin!!  (Read 1159 times)
Offline g-mac-gti
  • GTI 8V
« on: 29 March 2009, 23:39 »
how do i go bout fixin it?
is it a cable like speedo or some gearbox jobbie?
damzel in distress please help
BAD ASS GIRLS DRIVE BAD ASS TOYS
Offline danny_p
Re: my rev counter stopped workin!!
« Reply #1 on: 29 March 2009, 23:41 »
it works off the LT ignition circuit   wire has probaly fallen off coil
all the VW's have gone bar 1.
Offline g-mac-gti
  • GTI 8V
« Reply #2 on: 29 March 2009, 23:48 »
aaaah sweet...is it a pain in the arse job to sort?
Offline paulyV6
« Reply #3 on: 30 March 2009, 00:20 »
Have you tried hitting the top of the dash directly above the rev counter.
I find a good smack with an open hand usually gets my rev counter / dash lights working again!
Offline g-mac-gti
  • GTI 8V
« Reply #4 on: 30 March 2009, 08:33 »
ooooh il give it a try  :grin:
« Reply #5 on: 30 March 2009, 10:10 »
check the red/black wire attached to the coil :)
failing that, pull the fuse for the clocks for 30 seconds
Offline dubber36
« Reply #6 on: 31 March 2009, 17:15 »
Dont worry about it. It'll just be having a little rest. It'll work fine again when it wakes up.
Offline paulyV6
« Reply #7 on: 01 April 2009, 00:17 »
Mine all stopped working again yesterday - the slap technique didn't work, but disconnecting/reconnecting the battery worked
Offline g-mac-gti
  • GTI 8V
« Reply #8 on: 01 April 2009, 20:16 »
when it was snowin bad i dint drive it for 2 days. then i was takin it to the body shop and battery was flat, so charged battery and noticed mfa, horn and rev counter werent workin.
saw my car on sunday and the clock looks like its ack to normal. totally forgot about my horn but they gy said rev counter still isnt workin. ill have a gander when i get it back.
cheers for advice guys
Offline shep-mk2
  • Re-standardising the 8V
« Reply #9 on: 03 April 2009, 20:07 »
My rev counter didn't work when I got the car, I changed the clocks which was a bit of a pain but the MFA wasn't working either so it was worth it, however......
....when I got it all back together, the indicators didn't work and instead the stalks operated the horn! Imagine my surprise!!!!
Seemingly, it's really easy to slot the flat pins into other sockets so be aware of that.  Bear in mind as well that if you do have to change the clocks it is a dash out job and it's really easy to break stuff as I found out at a cost!
Who would have thought that reverting back to standard would be this expensive!!!!
