Author Topic: How to find out which engine I have?  (Read 3358 times)
Offline Deefadog
  • Mk2 16V (November 89)
« on: 21 July 2004, 12:50 »
As mine is an 89, when I am buying bits for the engine such as ht leads I am asked is it 1988-89 or 89-92.
How to find out which one it is?
i can post a pic if it helps
thanks
Offline Dizzie
  • Make friends with your fast
Re:How to find out which engine I have?
« Reply #1 on: 21 July 2004, 12:52 »
they're the same if both 8v's
may aswell tell them it's a 89 though. only confuses the poor souls
« Last Edit: 21 July 2004, 12:53 by Dizzie »
Offline Deefadog
« Reply #2 on: 21 July 2004, 12:59 »
It's a 16V, sorry forgot to mention that :)
Offline Gambit
« Reply #3 on: 21 July 2004, 13:14 »
is your car a big bumper model? if so then its an 89-92
shouldnt make a difference though with 16v's as the same engine is used throughout the 16v golf lifespan, only difference is with the airflow metering head/airbox which is different in big bumper models
« Last Edit: 21 July 2004, 13:15 by Gambit »
Offline Deefadog
« Reply #4 on: 21 July 2004, 13:27 »
Yes it has big bumpers (but these could have een put on later I guess). I'll post a pic of the engine tonight so you can tell me by the airflow metering head/airbox.
Thanks again
Offline Gambit
« Reply #5 on: 21 July 2004, 13:39 »
if the hazard light switch is on top of the steering column then its a late spec car
early spec had the switch on the dash beside the rear window heater switch
Offline Dizzie
« Reply #6 on: 21 July 2004, 13:41 »
the engine should be the same in either model though. it was mainly the electronics side that changed.
Offline Gambit
« Reply #7 on: 21 July 2004, 13:46 »
late airboxes look like this
Late 16v Airbox
Offline Deefadog
« Reply #8 on: 21 July 2004, 15:24 »
Yep, that's the same as mine :)
So I have the latest one then?
What's the engine then?
Offline Gambit
« Reply #9 on: 21 July 2004, 16:29 »
engine code on all 16v's is KR then a pile of numbers - it'll be stamped on the tax book aswell
