Author Topic: IS this a problem???  (Read 1330 times)
Offline ajgti 16v
« on: 29 March 2009, 00:36 »
Hi Ive done a conversion from a 8v to 16v.the 8v was out of a seat ibiza 1999,but the ecu failed so I had a 16v engine and shell its a 1988 16v.I have the conversion done .I changed the timing and full service.but the car has no power.it will start but will not pick up speed.IS THIS BECAUSE I AM STILL USING THE 8V FUEL PUMP ?
         I ALSO SUSPECT THE VACCUM PIPES MAY HAVE BEEN FITTED WRONG?
PLEASE HELP ANY ADVISE NEEDED
aj
Offline danny_p
Re: IS this a problem???
« Reply #1 on: 29 March 2009, 02:48 »
no need to shout,    kjet dont work with 8v digifant pump very well on a good day,   suprised it even ran
all the VW's have gone bar 1.
Offline Ben Lessani
« Reply #2 on: 29 March 2009, 11:22 »
As danny said, you need a k-jet fuel pump - its a much higher pressure than digi. Also given that k-jet runs on the inlet vaccuum, if you've got any leaks, its going to run like crap or not at all.
The fuel pressure needs to be around 75-84 psi whereas on digi its more like 40 psi IIRC
Offline ajgti 16v
« Reply #3 on: 29 March 2009, 22:24 »
Thanks I know this mite be a obvious,but if I use the orginial 16v pump should this work ???
aj
« Reply #4 on: 29 March 2009, 23:19 »
Yes, I think so.
Offline ajgti 16v
« Reply #5 on: 29 March 2009, 23:23 »
cheers I am going thru torture my car is off the road since b4 xmas I only had it one wk when I realisied I had to so the conversion but I havnt driven it in 3mts.awfull luck.
aj
« Reply #6 on: 30 March 2009, 10:20 »
you need the fule lines from pump to bay as well
