Author Topic: 16v running on three?  (Read 2139 times)
Offline skem55
« on: 28 March 2009, 23:40 »
hi all, been furiously trying to get my mk2 ready for the road after some major tidying to the bodywork, now ill stress that the car has been moved in and out of the garage at the house on a near daily basis! was idling lovely bit high at times but hey.
Went to move the car out today and lets just say i thought someone had unplugged a lead!
The only thing ive done lately is removed the slam panel but i doubt this would cause the thing to run on three!
I havent check anything on the engine yet apart from the obvious connections like leads to plugs and leads to dizzy everything is plugged in fine?
Just wondering has anyone had this problem before, just randomly dropped to three cyclinders or is my little project screaming at me to hurry the fook up and get it on the road? and give it a good run?
Advice will be appreciated
cheers stuart
Offline Ben Lessani
Re: 16v running on three?
« Reply #1 on: 28 March 2009, 23:44 »
shouldn't the title be 12v running problems :laugh:
If its not firing on all four, do the obvious first, check the spark plugs, dizzy/rotor and esp ht lead, then proceed to check cyl. compression.
Offline skem55
« Reply #2 on: 28 March 2009, 23:47 »
yea you probably right ben shud be gti 12v!! :laugh:
yea i no ill have to actually have to stop the bodywork and sort it or hurry finish the body n then figure it out, just wierd that one night reversed it in the garage was fine, next morning go to drive it out and it sounds like a chevy lump!
oh and its over fueling so im heading straight to the sparks to start with probably find a wet one!
stuart
Offline Ben Lessani
« Reply #3 on: 28 March 2009, 23:51 »
If its overfuelling then you probably have your answer? It is a digi / kjet? Injectors are buttons anyway so if one is a bit eager, it should be easy enough to resolve.
Offline skem55
« Reply #4 on: 28 March 2009, 23:54 »
its a kjet system, yea i thought i mite have a leaky injector but just aint time to investigate as been removing the old sh!tty bodywork lash up from whoever owned previously!
so u going for an injector then ben?
stuart
Offline Ben Lessani
« Reply #5 on: 28 March 2009, 23:59 »
Who knows, get it idling then just drop the plug and you'll soon see.
Offline skem55
« Reply #6 on: 29 March 2009, 00:02 »
wat do the old investigate wat cyclinder jobby then, mmm scooby time lol last time i removed the leads on a vts and it sounded like a scooby running on two lol
will have a go tomoro and then be back ere tomoro nite wen i find fook all lol!
stuart
Offline danny_p
« Reply #7 on: 29 March 2009, 02:56 »
my old engine turned itself into a 3cyl  :sad:     but yous sounds less terminal, probs an injector ht lead or even just a spark plug may have given up
all the VW's have gone bar 1.
sharpie
« Reply #8 on: 29 March 2009, 15:23 »
a 16v running on 3 cylinders is a bit like running a vr6. sounds cool as f**k but certainly doesn't go anywhere quickly.
Offline Ben Lessani
« Reply #9 on: 29 March 2009, 21:04 »
I had a Daewoo Matiz as a courtesy car a while back and it was brilliant fun - the engine is only a 3 cyl and its really growly when its running! Same as my cousins Smart Brabus - sounds awesome!
