Author Topic: how would i know a mis-fire when i had one?  (Read 777 times)
Offline edpryce
« on: 28 March 2009, 18:41 »
Ok, So a lot of threads on mis fires but none saying what they are.
took the car out today first time in months after my slight issues in january.
anyway, enjoyed a good blast through the peak district and it ran fine. I then noticed the car was beginning to struggle. It was hesitating after i planted my foot, mostly between 2-3,000 revs, and then would jerk and pick up. Similar feeling to wheel spinning i suppose, but it was doing it in all gears.
the weather took a turn for the worse as this was happening and i know damp can cause this?
is this misfiring? and if so, is it just plugs and dizzy cap?
got pretty annoying/scary when overtaking.
I should say, i had the alternator off the other day, and am running without a top timing cover. could these make any difference at all if it wasnt on right? i would think no but may as well give all the information i can.
84 k-jet gti
Ed
Offline sidecarphil
Re: how would i know a mis-fire when i had one?
« Reply #1 on: 28 March 2009, 19:12 »
it is usually leads
but i would change the plugs ,leads and dissy cap , rotor arm
buy some good quality leads like Beru
Offline edpryce
« Reply #2 on: 28 March 2009, 19:19 »
will do
cheers
Offline Croline
« Reply #3 on: 29 March 2009, 12:36 »
Ditto, plugs and dis cap definitely the issue!
