Author Topic: 16v starter motor  (Read 1101 times)
Offline beechymonza
  • mad beech
16v starter motor
« on: 28 March 2009, 12:58 »
my starter motor has been playin up lateley, its 1988 16v, in my local scrappy is mk3 16v, would starter of this fit on mine :huh:
No guts No glory,
Offline Diamond Hell
  • Opinions я Us
Re: 16v starter motor
« Reply #1 on: 28 March 2009, 13:22 »
don't think so - Golf3 = cable change gearbox, Golf2 = rod-change.  Totally different flywheel arrangement and gearbox.
« Reply #2 on: 28 March 2009, 19:39 »
As above no, I don't think it would fit.
Offline Ben Lessani
« Reply #3 on: 29 March 2009, 00:02 »
You sure its the starter and not the solenoid/wiring?
Just DIY refurb it, its easy enough and will cost buttons
« Reply #4 on: 30 March 2009, 10:24 »
only 16v and TDI MK3s are cable change, so as long as it isnt one of those then yes the starter will fit. only difference is the plug for the trigger wire is different, but the MK2 spade will fit the terminal on MK3 motor if you remove the plastic plug housing
edit: oh and not a 1.4 or 1.6, those are different
Offline beechymonza
  • mad beech
« Reply #5 on: 31 March 2009, 22:14 »
sorted it.prob with my immobiliser, sending an intermitant signal 2 my ignition, so fitted a push button start located on blankin plate where choke would be, still need immobiliser key and key in ignition, but just push button an away we go :laugh: :laugh:
No guts No glory,
