Author Topic: alternator belt keeps twisting and snaping help?  (Read 2034 times)
Offline jayz1981
« on: 27 March 2009, 16:46 »
hi as said above the water pump pully looks out of line with the crankshaft pully was going to push the water pump pully out abit with some washers any advice or help would b great
Offline danny_p
Re: alternator belt keeps twisting and snaping help?
« Reply #1 on: 27 March 2009, 17:30 »
quite possible one of the pullys is wrong one
all the VW's have gone bar 1.
Offline JimR
« Reply #2 on: 28 March 2009, 17:05 »
is it possible to have the pulley on the wrong way round?
Mk2 GTi.
Offline danny_p
« Reply #3 on: 28 March 2009, 17:20 »
wrong way round is a bit of a challenge but wrong one is easy done
Offline AdamMk2
  • Beautiful
« Reply #4 on: 29 March 2009, 23:50 »
Also to add to the pully issue check them for damage and that theyre not buckled or the recess is damaged or blocked with something causing it to jump out and that the dish of the pully is also not bent.
If no luck there mover the pullys and watch them as they spin giving you an idea as if to it being buckled which doesnt appear when forst looking at it
 :cool:
Good luck mate  :wink:
Offline jayz1981
« Reply #5 on: 08 April 2009, 19:20 »
hi all thanks 4 help i put washers behind the water pump pully seems to have sorted it  :rolleyes:
Offline Ben Lessani
« Reply #6 on: 08 April 2009, 21:48 »
I've got washers on my PAS pump - well, now its not individual washers, but 3 solid spacers. It will put more strain on the bearings long term, but as long as the washers are equal size - I wouldn't give it any grave concern.
