Author Topic: lowiring with 19" wheals  (Read 1501 times)
Offline burnett_gti
« on: 26 March 2009, 15:59 »
sorry i bet this has ben asked heeps of times i have 19" wheals on my mk5 gti
i wont to lower the car recameb what is best drop and combe springs or springs and shocks
can you tell me what offset the wheals shood be that are a et45?
if i lowere the car will i get any scufing ie gowing over bumps and turning lock to lock or will i need spacers
alan
ps sorry about the spelling dislecik
« Last Edit: 26 March 2009, 17:00 by burnett_gti »
Offline Hurdy
Re: lowiring with 19" wheals
« Reply #1 on: 26 March 2009, 19:56 »
I too have 19" wheels, but mine have a slightly higher offset at 48. What width are the wheels? 8.5" wheels are more likely to rub when lowered than 8" ones as they stick out another 6mm with the same offset?
The car is lowered by 30mm over stock on coilovers and I have no rubbing issues. I also did the wheel arch screw mod to give the car an extra few mm's of clearance.
Car as it is now.
Diagram showing offsets for info. :smiley:
HTH
Seat Leon Cupra Black 290 DSG
Offline burnett_gti
« Reply #2 on: 26 March 2009, 21:18 »
thanks for the reply the wheels are 19"x8 was hoping to lower about 30mm!!
can you tell me what is the screw mod is?
alan
Offline Hurdy
« Reply #3 on: 26 March 2009, 23:10 »
The screw mod is a trick that can be done to the front arches to give a little more clearance for the wheels. If you feel under the highest part of the front arch your fingers will run over a screw head. It is this screw which tends to catch on the wheel first. By removing the screw and its plastic fixing, then tucking the arch liner behind the metal screw locater bracket on the arch and finally bending gently (by hand) the metal bracket back into itself you will get a good 3 to 5mm extra clearance. :nerd:
Offline neg
« Reply #4 on: 26 March 2009, 23:42 »
Side note - now that looks better Hurdy, some decent rims on it  :wink:
Offline Hurdy
« Reply #5 on: 27 March 2009, 09:57 »
Cheers :cool:  Bought at a goooooooooood price too :wink:
