Author Topic: Decat's...  (Read 1397 times)
Offline twistedblack69
  • Proud mk2 user and abuser
Decat's...
« on: 25 March 2009, 22:17 »
Anyone here got one?? Am thinking of doing it, mainly because I can haha...just wondering if there's any pro's or con's to it at all?? What are you're personal preferences on them?? Does it do anything to power?? I really don't know anything about them except I couldn't do it on my old car, but I can on my Golf haha
Offline nealey
Re: Decat's...
« Reply #1 on: 25 March 2009, 22:28 »
Are you sure your golf even has one, it was a very expensive option that took away a fair bit of power so it wasnt a popular option
Offline Benrevs
Re: Decat's...
« Reply #2 on: 25 March 2009, 23:12 »
Post edited, my mistake! :wink:  You will gain taking it off.. just not hugely
Offline Khare
  • The bear that khares
Re: Decat's...
« Reply #3 on: 25 March 2009, 23:14 »
as above. back in the late 80s/early 90s people gave two sh!ts about the enviroment and rarely ticked the yes on the option list. Few mk2s have cats.
iirc your car put out 101hp at the RR didnt it? If i were you, id try and get back to standard 112hp. A full service and a tune up of the engine is a must mate, it will reset the car back to 112hp and it will totally transform it. before you start modding, make sure you've got a good base. no point in trying add mods to get standard figures, mods are for figures above standard  :wink:
oh and a decat pipe will give about 4 or 5 hp, and the car will hold it's power for longer, so you wont run out of puff at 5000rpm.
Re: Decat's...
« Reply #4 on: 25 March 2009, 23:15 »
I wasn't sure if it was supposed to be a power gain or a power loss, just heard about them, hence me saying I don't know much about them. So you can't get a decat pipe for a mk2??
Benrevs...yea that's what I meant by I couldn't on my old car, it being a '95 Fiesta, my Golf is a '91 H reg, and yea, anything post-J reg it's mandatory to have a cat to get through it's MOT, and possisbly other legal reasons, I'm not sure
Offline Benrevs
Re: Decat's...
« Reply #5 on: 25 March 2009, 23:34 »
For some VERY strange reason I thoght I was in the mk3 section!.. :embarassed:
Offline jamie_pyrite
Re: Decat's...
« Reply #6 on: 26 March 2009, 00:00 »
Anything older than '93 and you can get rid of it :) I'm currently arranging to have my 1.6 Jetta de-cat'd.
I've talked to a few parts places locally and none of them have the section to replace it with.. They said it isn't made anymore! It's going to have to be a garage job and get the Cat cut out and replaced with a bit of pipe.
Offline nealey
Re: Decat's...
« Reply #7 on: 26 March 2009, 00:08 »
If your car does have a cat the best way to get the most from it is to ditch the cat and also fit a pb engine code engine ecu
Offline sidecarphil
Re: Decat's...
« Reply #8 on: 26 March 2009, 06:32 »
the PB code ecu wont work you need the PF code one
keep the lambda probe though
i know i tried it when mine went pop
i should have had a cat but it was removed long ago
think it is just a new front part of the exhaust you need
