Author Topic: boost prob ??  (Read 2433 times)
Offline ALEXS1.8T
  • golf 1.9tdi 90bhp
boost prob ??
« on: 24 March 2009, 16:53 »
hi there as you know i fitted my boost hoses and 007p in the last few days iam well happy with them BUT,
when i fitted the boost hoses sat i took it for run seemed fine but i noticed when you put your foot down flat the sounds of the boost seemed to be on and off like a swirl noise  but seemed to be pulling as normal not reall noticed any on and offs with the pulling.
now i have fitted the 007p i took it out again and i can here the same noise a bit more but drive seems ok .
have u guys got any ideas on wot could be happening???  i dont have a vagcom so no faut codes ........
its weird thats its now makein this noise??  :undecided:
now drivin a golf 1.9 tdi 90bhp ... time to rack up them miles!! as my daily
Offline ryanr32
Re: boost prob ??
« Reply #1 on: 24 March 2009, 17:29 »
are you sure you have fitted the hoses down properley and fitted the clips tightley!
Offline ALEXS1.8T
  • golf 1.9tdi 90bhp
Re: boost prob ??
« Reply #2 on: 24 March 2009, 17:31 »
they all seem ok but i wont b usein the car till weekend now , so i will check them all again.   if a hoses is not tight enuf is there a way of telling???
Offline ryanr32
Re: boost prob ??
« Reply #3 on: 24 March 2009, 17:37 »
it will be unlikley that any have split so all you could do is just check all the jubilee clips are tight! might even be a faulty MAF! :undecided:
Offline ryanr32
Re: boost prob ??
« Reply #4 on: 24 March 2009, 17:42 »
sorry read i competly wrong i thought you said you hit some flat spots while putting your foot down! :embarassed:! if its just a swirling sound then its proberly just your turbo spooling up! mine does the same!
Offline ALEXS1.8T
  • golf 1.9tdi 90bhp
Re: boost prob ??
« Reply #5 on: 24 March 2009, 17:43 »
could the fitting of the hoses etc make the MAF faulty as it has all been fine untill now lol. i might give jkm a ring tomorrow and see how much they will charge me to fit my TIP andcheck all my hoses are on ok , and then find my prob if its not a hoses etc
Offline ALEXS1.8T
  • golf 1.9tdi 90bhp
Re: boost prob ??
« Reply #6 on: 24 March 2009, 17:45 »
does yours sound like the whitsle noise  whistles as normal but drops in sounds and the whistles loud again and so on , up and down with the pitch of the sound.??
Offline ryanr32
Re: boost prob ??
« Reply #7 on: 24 March 2009, 18:06 »
yes mate mine also sounds like a whisling noise! we have ether got the same problem or thats how its meant to sound :huh:
Offline ALEXS1.8T
  • golf 1.9tdi 90bhp
Re: boost prob ??
« Reply #8 on: 24 March 2009, 18:14 »
 :undecided: i aint got a clue , but i know mine didnt used to do the drop in sound then back up again . like it is now when foot is flat to floor.
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: boost prob ??
« Reply #9 on: 24 March 2009, 18:42 »
does sound like a boost hose isnt on correctly and from what ive been reading it may be the hose coming off the top of turbo.
