Author Topic: dodgy electrics-help!  (Read 2156 times)
Offline scrossy
« on: 24 March 2009, 15:37 »
Hi guys,
i bought i mrk one GTI clipper cabriolet and the temp gauge dosnt work but the warning light flashes randomly when dipped headlights are on but not beam etc. Then the fuse blew for the radio and indicators, i changed the fuse and now something else has blown not sure what though any ideas? im new do this game if you hadn't guessed. :huh:
Offline raferackstraw
Re: dodgy electrics-help!
« Reply #1 on: 24 March 2009, 21:01 »
hi mate first off do a search of similar problems using search function
check your fuse box hasnt got damp ragtops do leak if not looked after, are carpets in passenger footwell damp?
if its an aftermarket radio if so remove it and check its wired correctly
you could also have a bad earth but do a search it helped me resolve most of my issues
wayne gardner smokes one rothmans too many
500cc 2stroke bad for ya health
Offline Stone0311
« Reply #2 on: 25 March 2009, 20:20 »
Water Commonly comes in the bottom of the windscreen onto the fuse box or check the drain holes in the chamber at the top of the engine bay - had the same issue in my cabby  > new windscreen seal (£40 for national windscreens) sorted it out a treat
« Reply #3 on: 30 March 2009, 09:45 »
sounds liek an earthing fault, check for any loose brown wires behind dash. might be worth finding browen wire from dash cluster and splicing in a fresh earth to the chassis?  Also check the red/yel wire in the engine bay, it should be attached to a small single pin sensor on one of the water flanges on the front/side of head, if you earth it to the block the dash gauge should shoot to max. if it does that but still no reading when connected then you need a new sensor
