Author Topic: Mk2 Gearboxes  (Read 2587 times)
Offline promethius7
Mk2 Gearboxes
« on: 23 March 2009, 20:05 »
Does anyone know if theres a stronger gearbox to fit a mk2 16v with as little mods as possable?
Offline Mk2Kezza
Re: Mk2 Gearboxes
« Reply #1 on: 23 March 2009, 20:20 »
I suppose it depends on what you mean by stronger? Are you planning on modding the 16v?
Many of the Mk3 boxes will fit - they are newer but you'll have to check the code on the bell housing to get one with the same/similar ratios.
I'm sure someone will give you a difinitive  answer as to whethre they are stronger....?
<br />Almost finished.....
Offline Diamond Hell
  • Opinions я Us
Re: Mk2 Gearboxes
« Reply #2 on: 25 March 2009, 09:56 »
I've got a Golf3 16V cable-change gearbox, with the complete shift mechanism here.  You'd need to run a Seat Cordoba O/S driveshaft and a Seat cable clutch, but that should see you well past 200bhp without batting an eyelid.
VeeDubGTI16v
Re: Mk2 Gearboxes
« Reply #3 on: 25 March 2009, 10:34 »
have been looking at this recently. the golf 3 16v box is too tall compared to the mk2 one. for a standard cable change gearbox the corrado 1.8 16v is the best ratio'ed for a mk2 16v. after that you have to piss about with final drives
Offline mattkh
Re: Mk2 Gearboxes
« Reply #4 on: 25 March 2009, 17:37 »
Hi
Do you know what code the corrado gearbox is. Cheers
VeeDubGTI16v
Re: Mk2 Gearboxes
« Reply #5 on: 25 March 2009, 18:48 »
its AGC.
heres the theoretical speeds with 195/50/15
           1     2      3       4       5
02o 2y   37     61     90     115     143
02a agc 32     57       90     124     152
02a cda  39   67     99     126     155
neither are ideal really, what im gonna go for eventually is the cda (mk3 16v) with a 4.2 fd to make
            34      58     86   110   136
Offline gixerthrasher
Re: Mk2 Gearboxes
« Reply #6 on: 25 March 2009, 20:31 »
I've been thinking about this too.. Surely a 16v box in good order can handle 200bhp? The ratio's are perfect it seems??
My Mk2 16v gearbox is a little slack now, so would it be cost effective to get a recon box & fit that? Does anyone know where to get one?
The engine is going to be replaced with a 2ltr, gas flowed 16v head & Piper cams, so I'm hoping the box will take it through a HD clutch???
Never hold your farts in.. They travel up your spine and into your brain and that\'s where sh!tty ideas come from!
Offline re2
Re: Mk2 Gearboxes
« Reply #7 on: 25 March 2009, 20:40 »
16v boxes are stronger than 8v boxes anyway, so i cant see why a standard one wont see 200bhp.
Offline danny_p
Re: Mk2 Gearboxes
« Reply #8 on: 25 March 2009, 21:03 »
diff rivets are still the same and they go bang first,       16v box with a bolted diff is tougher than 8v box with bolted diff.
a ported and cammed valver 2.0 will eat diff rivets if you drive it like it should be driven
all the VW's have gone bar 1.
Offline re2
Re: Mk2 Gearboxes
« Reply #9 on: 25 March 2009, 22:00 »
ooops- i forgot about those dreaded rivets!
