Author Topic: Milltek - edition 30 spec on a GTI???  (Read 1676 times)
Offline starsky
« on: 23 March 2009, 18:59 »
I thinkin of gettin a Milltek and note that the edition 30 has 80mm twin end pipes compared with the GTI that has 76mm twin jets. Anyone know if an edition 30 spec will fit a normal GTI?????
They appear to both have 69.85mm pipe diameters so in theory the should fit. Any help would be appreciated.
ta
2006 Golf GTI Mk5, 1997 Golf GTI Mk3 Anniversary - Both gone, but not forgotten...Just arrived Golf GTI 16v Mk3!!!!!
Offline Gene Hunt.
Re: Milltek - edition 30 spec on a GTI???
« Reply #1 on: 23 March 2009, 20:15 »
If it's just the tail pipe's that are bigger i don't see why it won't fit ?.
Candy White ED35.
Offline Hurdy
« Reply #2 on: 23 March 2009, 20:16 »
You may have to do some work to get the ED30 version to fit from the cat-back, but the main difference is the downpipe from the Turbo.
The 80mm ends on the ED30 version are a much better design than the 76mm ones and if you can make it fit, I'd definitely choose the ED30 tails.
Seat Leon Cupra Black 290 DSG
Offline RobGTI
« Reply #3 on: 23 March 2009, 23:40 »
I've got a Leon FR which lists the GTI cat back as being compatible with the Leon, so I thought I'll get the Ed30 one instead as its abit nicer and bigger. I did not fit at first the tailpipes being too short but after a bit of modding (extending the taipipes) about 150mm it fits a treat (cost about £60 to do). So therefore the Ed 30 will fit the GTi according to the same logic.
Edition 30, Black, 3 dr, Manual, Xenons, Highline, Sunroof, Armrest, Cruise, Touchscreen Nav & Bluetooth.
Offline Dogbucket
  • Golf R32 / TVR Chimaera 450
« Reply #4 on: 24 March 2009, 07:28 »
the GTI/ED30 Milltek systems use the same middle sections so it should go straight on.
Offline starsky
« Reply #5 on: 27 March 2009, 21:36 »
cheers for the advice guys, i got confirmation from milltek that it does fit so i ordered one. will post pics when fitted!
Offline Gene Hunt.
« Reply #6 on: 29 March 2009, 10:09 »
.........please do. :smiley:
Candy White ED35.
