Author Topic: ARGH car broke down tonight  (Read 3078 times)
Offline dai-cymru
  • 1989 MK2 16V
« on: 22 March 2009, 23:04 »
FECKING GOLF was out with the wife this evening driving for an hour or so and then heading home it cut out and wouldnt start  :angry: got it start then it ran like sh!t and cut out, think this is all coming back from the ecu fault and it's finally catching up with me quick vag com and this is what i got  if i cant get it sorted this week wont chance the RR bit far to break down  :cry: :cry: :cry:
Sunday,22,March,2009,20:46:27:31031
VCDS Version: Release 805.3
Data version: 20090213
                Address 01: Engine
Control Module Part Number: 06A 906 032 DR
  Component and/or Version: 1.8L R4/5VT         0003
           Software Coding: 11500
            Work Shop Code: WSC 00000
4 Faults Found:
16622 - Manifold Pressure / Boost Sensor (G31): Signal too High
        P0238 - 35-00 -  -
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
        P0106 - 35-00 -  -
17705 - Pressure Drop between Turbo and Throttle Valve (check D.V.!)
        P1297 - 35-00 -  -
17704 - Error in Mapped Cooling System (check Temp-Sensor and Thermostat)
        P1296 - 35-10 -  -  - Intermittent
Readiness: 0010 1001
Offline bobbarley
  • I'm kind of a big deal...
Re: ARGH car broke down tonight
« Reply #1 on: 22 March 2009, 23:05 »
Gutted!!  :embarassed:
Offline richw911
« Reply #2 on: 22 March 2009, 23:07 »
Damm rhys was telling me about this  :cry: :cry: :cry:
17705 boost leak  :undecided:
Split pipe?
Offline dai-cymru
  • 1989 MK2 16V
« Reply #3 on: 22 March 2009, 23:08 »
Split pipe?
been right through the pipework twice, pretty sure it's the ecu as the throttle body hardly opens when you press the pedal
Offline richw911
« Reply #4 on: 22 March 2009, 23:11 »
Split pipe?
Hmmm As rhys was saying - has nick got one you can borrow?
Offline dai-cymru
  • 1989 MK2 16V
« Reply #5 on: 22 March 2009, 23:16 »
Split pipe?
Havent asked yet mate, would like to try one first just to see, spent just over £500 on it since the engine and she still wont run tidy. Scoured the classifieds and ebay no ECU's with my part number been looking for a few weeks
Offline Voodoo-Music
« Reply #6 on: 23 March 2009, 01:54 »
This happened to me and all that had happened was it popped the boost pipe after a remap
Offline bobbarley
« Reply #7 on: 23 March 2009, 06:06 »
Split pipe?
Breakers yard?
Offline dai-cymru
  • 1989 MK2 16V
« Reply #8 on: 23 March 2009, 08:38 »
Going to have another look today me thinks  :smiley:
Split pipe?
Breakers yard?
tried loads and entered my details into breakers yard.com still nothing at the moment  :undecided:
Offline T_J_G
« Reply #9 on: 23 March 2009, 08:47 »
Damn, I'm sure Nick may lend you one if he has one..
