Author Topic: Steering wheel boss  (Read 3721 times)
Offline a16vvw
Steering wheel boss
« on: 19 July 2004, 16:29 »
My 1990 16v seems to need a large holed boss to fit it to the spindle.  It lloks like the spindle has a adapter bit on it that makes it wider than the 1989 golf spindle.  the question do i need to try and extract this bit off or can i buy a boss that will fit.  The  mountney Boss from Halfords for 1990 golf does not fit the hole is too small.
Sorry if this message is a bit messy but its a tricky subject to explain.  I'm sure there's someone out there whos solved this problem.
Cheers for any response
Offline tobz.
Re:Steering wheel boss
« Reply #1 on: 19 July 2004, 16:38 »
Hi
The steering column diameter changed over to a thicker gauge around 1988-90 (not sure exactly when). If yours is fitted with an adaptor piece the chances are you have the earlier narrower column. The best bet is probably to try an extract the adaptor and buy the correct boss for your steering column. There should only be two sorts available the early one or the late one. Hope this helps.
Just out of interest is your username based on a number plate and if so do you live in fulbourn cambs???
Toby
You got any pics of your dad's split ?
Offline a16vvw
« Reply #2 on: 20 July 2004, 09:11 »
Hi Toby
Cheers for reply.  I have been told by a vw mechanic that the adaptor looking bit on the column is a bast"%$ to take off and that it is keeping bits of the steering column in place.  What I'd like to do is find a boss with the large diameter hole.
It is based on a Reg but I dont own it (I wish!) Not from that way either.
I'm sure other MkII enthusiasts have had this problem.
Where can I buy a boss with the large hole?
Cheers dan
Offline tobz.
« Reply #3 on: 20 July 2004, 09:42 »
Hi Dan
Last time I had to buy a boss for my momo wheel I used these guys:
http://www.awesome-gti.co.uk/default.htm
I'm not sure if they stock mountney or not but are probably worth a try.
I asked about your username as the guy who does own a16 vvw lives just round the corner from me. He has the plate on a grey mk2 16v. He also owns a couple of gorgeous mk1 campaigns aswell as various other cars (bmw, merc, mini one etc etc) lucky git. I just thought if you had been him I would finally get to have a proper look at his golfs.
Good luck with the boss
Toby
« Reply #4 on: 20 July 2004, 09:52 »
The adaptor is indeed a b1tch to remove, you need a puller and even with one of them I had to use a pair of pliers as well to get a decent grip on it.  The adaptor doesn't hold anything on, but there is a spring behind it which is compressed by the wheel.
« Last Edit: 20 July 2004, 10:01 by rubjonny »
Offline a16vvw
« Reply #5 on: 20 July 2004, 12:50 »
Ah nice one
Why did VW have to go and change things all the time.  So you can get it off then any older wheel will fit? how about a boss that fits with the adapter still on.
I've searched for that plate b4, wonder how much it's worth?????
Cheers Dan
Offline philadams16V
« Reply #6 on: 20 July 2004, 13:21 »
Hi dan,
I've just checked the diameter of my standard 1990 mk2 16V steering wheel spindle hole and its 30mm.  Hope this is some help to you.
Cheers Phil  ::) :P ;D
« Last Edit: 20 July 2004, 13:22 by philadams16V »
« Reply #7 on: 21 July 2004, 10:57 »
Yup, one the adaptor is off, any wheel that fits to older models will go straight on.
Offline BaldyBastard
  • Project Darkee in killed :-(
« Reply #8 on: 22 July 2004, 16:35 »
If you need a boss for the later model MK2 golf let me know, I have one spare  ;D
- The liver is EVIL and MUST be punished -
** breaking a Black MK2 Driver (H reg) - PM if you need any bits **
Offline a16vvw
« Reply #9 on: 23 July 2004, 16:37 »
Will it fit a steering wheel with 75mm centre to centre holes.  I think I'm going to try and et the adaptor off though!
Dan
