Author Topic: help !!!!!  (Read 2735 times)
Offline jamesg1990
  • 18 and on his second Golf GTi!
Re: help !!!!!
« Reply #10 on: 22 March 2009, 18:27 »
Rhyso have you got a link to the pancake pipe thread?
My 1.8T has oil around it and I seem to be topping up the oil every week :sad:
hmm that doesn't sound good!
see this link
http://uk-mkivs.net/forums/p/246330/1594620.aspx#1594620
do you notice any puddles under the car if its been stood??  whats the performance like? any smoke out the exhaust?
Performance seems fine, theres no black smoke or oil puddles.
Every week the oil level drops from right in the middle of the dipstick to just above minimum, I take it this is not normal for these engines?
Offline Rhyso
Re: help !!!!!
« Reply #11 on: 22 March 2009, 18:29 »
see this link
no you shouldn't be topping the oil up every week!! unless you do over 1000 miles a week........
most will only have to top around 0.5 to 1 litre between each service, some won't need a top up at all
i take it you check the oil when the engine is cold??
Offline jamesg1990
Re: help !!!!!
« Reply #12 on: 22 March 2009, 18:38 »
see this link
Argh damn car.
Yeh the engine is completely cold when checked. I noticed that there was a bit of oil around the pipe that is connected to the pancake pipe so I cleared it all off and checked it the following week and it had oil on it. The jubilee clip did seem a bit loose though?
Offline Rhyso
Re: help !!!!!
« Reply #13 on: 22 March 2009, 18:40 »
see this link
Argh damn car.
intercooler or turbo end??  if you can pop the connection off between the pancake pipe and the intercooler and look in there
if it literally pours out you have a problem; if its a thin film then thats normal as per the thread i posted a link to
worse case scenario is that the seals on your turbo are on the way out  :sad:
Offline jamesg1990
Re: help !!!!!
« Reply #14 on: 22 March 2009, 18:45 »
Turbo end I think, sorry Rhys havent had the car long so not too clued up on turbo stuff. It's the rubber pipe coming from behind the engine that connects to the pancake.
I'll have a look tomorrow in the pipe. If the turbo seals need replacing am I looking at a huge bill?
Offline Rhyso
Re: help !!!!!
« Reply #15 on: 22 March 2009, 18:47 »
no worries mate - that does sound like the turbo pipe
sadly yes - it will be either a refurb (if thats possible - not sure about the seals) or new turbo  :cry:
Offline richw911
Re: help !!!!!
« Reply #16 on: 22 March 2009, 19:37 »
I never have to top up my 1.8T and it gets used!!
Your looking at around 500 for a new turbo + labour to fit  :cry:
