Author Topic: just a few queries  (Read 1540 times)
Offline Argyle
just a few queries
« on: 20 March 2009, 16:03 »
ive got quite a bit of money saved now for a 1.8t gti and im thinking about just saving a bit more and doing all my engine/power mods at once, so just wondering what power figures  i'd be looking at if i was to save that bit extra and do  the following.....
Panel filter, cat back or turbo (with sports cat) exhaust, a recirculating valve?? (dunno if thats right or not? the forge 007 one??) a fmic and then a r-tech remap. obviously itd b wise for me to do the g60 flywheel and clutch swap aswell right??
Dan
« Last Edit: 20 March 2009, 16:07 by Argyle »
Offline Hulmie
  • White MK4 1.8T AGU K03s
Re: just a few queries
« Reply #1 on: 20 March 2009, 16:24 »
if you go for the later model mk4 fitted with K03s turbo, with the above mods and a stage 2 re-map you should be looking around 220 - 230bhp.
If you go for the earlier model fitted with a K03 turbo then you would be looking at around 195-200bhp
The G60 flywheel and clutch swap is a good upgrade as the flywheel is lighter than the standard dual mass clutch.
Before spending though make sure when you buy the car all the mechanical workings are in good order and service history is upto date.
Offline T_J_G
« Reply #2 on: 20 March 2009, 16:55 »
Don't bother with the new flywheel and clutch tll yours dies!
Offline richw911
« Reply #3 on: 20 March 2009, 18:39 »
+1  :wink:
Offline Argyle
« Reply #4 on: 22 March 2009, 00:35 »
+1  :wink:
ahh ok, would the standard one be able to take the extra power for a while then?
Offline Ivor Mk4 Turbo
  • 2014 PP GTi Manual
« Reply #5 on: 22 March 2009, 08:18 »
Depends how worn it is already. My standard clutch lasted for about 40k remapped miles with a couple of track days thrown in. ;)
« Last Edit: 22 March 2009, 08:20 by Ivor Mk4 Turbo »
Current Car:- 2014 GTI PP manual, white.
Make way for..... 'The Silver Bullet'! 227 bhp, KO3-S'd AGU, R-TECH Spec 2 map 8), Forge 007P, Blueflame Turbo-back, Eibach -30mm's, YellowStuff front/RedStuff rear pads, Goodridge braided lines, TT Short-shifter, R32 Dogbone, TT W/B bushes, Forge TIP, G60 fly/VR6 clutch, 5.5 ltr washer bottle,
Car now for sale >>> http://www.golfgtiforum.co.uk/index.php?topic=140614.0
Offline Argyle
« Reply #6 on: 22 March 2009, 12:08 »
ahh right then.
what year/reg/engine would i be looking at if i was to get the ko3s turbo then??
Offline Rhyso
