Author Topic: ev engine 2l bottom end  (Read 1523 times)
Offline bazzza
« on: 20 March 2009, 15:03 »
sorry about this but am takin my golf of the road  and goin to put the 2l bottom end in, i have ev engine .. what it is i was wondering dose a mk3 go straight in ?an what about the dizzy as mine go;s into  the the block not on the head ........ an do i need a mk3 gear box and flywheel  a head gasket an do i use my drive shafts thanks
Re: ev engine 2l bottom end
« Reply #1 on: 20 March 2009, 15:20 »
any mk3 2.0 8v block will do you, but you want a TSR dizzy adaptor kit. you have an adaptor ring + different dizzy gear to allow you to fit your old dizzy to the 2.0 block. apart from that pretty much plug & play
Offline re2
« Reply #2 on: 20 March 2009, 17:50 »
or use a 3a short block- if you can find one
Offline bazzza
« Reply #3 on: 20 March 2009, 18:40 »
how hard is it to change the dizzy gears
« Reply #4 on: 22 March 2009, 10:17 »
can be a nightmare, gotts punch out  a pin then the dizzy pops off. if you get a new pin you can drill out the old one worst case.
Offline bazzza
« Reply #5 on: 22 March 2009, 13:11 »
thanks mate can't find a tsr adaptor kit looks like a puttin a 1.8 bottom end back in  :undecided:
Offline Dr Gonzo
« Reply #6 on: 22 March 2009, 13:47 »
They do have them mate, i just got one myself about a month ago for a 3a engine, they're a bit pricey i think as anyone with acces to a lathe could turn the ring out but at least you'll know they're the right dimensions etc.  Have a look here:
http://www.tsr-performance.com/pages/engineparts.asp
Offline danny_p
« Reply #7 on: 22 March 2009, 14:32 »
chould arrange for some to be made if people are intrested
all the VW's have gone bar 1.
