Author Topic: No idle stabilzation with aircon on.  (Read 1150 times)
Offline dhuggins1
« on: 19 March 2009, 23:03 »
The idle does not increase to normal level when using the a/c, actually it bogs down to lower level.
Is there a relay or something that could be causing the prob?
Offline Rhyso
Re: No idle stabilzation with aircon on.
« Reply #1 on: 20 March 2009, 10:23 »
that sounds normal to me  :undecided:
whenever i engage my air-con you can hear the engine struggle that little bit more as the aircon draws its power and then when it disengages it returns to normal
Offline gjroe78
« Reply #2 on: 20 March 2009, 10:50 »
Yeah mate as Ryhso says, thats the norm mate
Offline MaXXeH
  • Golf MK5 GTI
« Reply #3 on: 20 March 2009, 11:24 »
mine picks up when the AC is put on.  and runs normal.
Offline jeynesey
  • Non VW but still VAG
« Reply #4 on: 20 March 2009, 11:33 »
Same for me, unless we all have the same problem???  :laugh:
Offline theshrew
« Reply #5 on: 20 March 2009, 12:14 »
Its normal for engine to bog down a bit when you first turn the air con on this is due to the extra load the air con puts on th eengine. Then after a few seconds the ecu will tell and change settings accordingly and it should run same as before. Apart from be down on power a little and use more fuel.
