Author Topic: GTi DSG Flywheel problem  (Read 5598 times)
Offline Saint Steve
Re: GTi DSG Flywheel problem
« Reply #10 on: 22 March 2009, 19:11 »
I've not heard of any real problems with either the fuel pump or the fuel pump.
 :laugh:
 :embarassed: Sorry my bad. Not very well and my brain must have been stuck in neutral.
re-edited :laugh:
or 2nd gear ahe John  :laugh:  :wink:
Offline mark.w
« Reply #11 on: 22 March 2009, 20:41 »
I've not heard of any real problems with either the DMF or the fuel pump. If it is the fuel pump it is worth noting that it is driven off the camshaft and the lobes have been known to wear prematurely, which can in turn cause damage to the camshaft. I'd be tempted to go with the one's quoting the fuel pump issue and get them to check the cam lobe as it is a relatively cheap fix compared to the DMF. :smiley:
thanks - yep, they're just checking it out on thurs, but have quoted for cam lobe and new fuel pump.
Offline mark.w
« Reply #12 on: 24 March 2009, 18:41 »
Not sure if anyone's following this, but i'm booked in for a replacement fuel pump. Full service history and no contribution from VW though, poor show. Still, £1000 cheaper than the replacement duel mass flywheel that was quoted.
Offline bacillus
« Reply #13 on: 24 March 2009, 19:08 »
Well at least you're going to be sorted without taking too much of a hit...    :smiley:
Without traction power is nothing!
Offline Hurdy
« Reply #14 on: 24 March 2009, 19:19 »
Good news then :cool:
Here's hoping that it sorts your issue.
Also, ask if you can keep the parts that they swap out. Firstly it gives proof that they have done the work and secondly, you can look at the parts for any damage....Pics on here please :smiley:
Seat Leon Cupra Black 290 DSG
