Author Topic: Best way to attack speaker problem?  (Read 3087 times)
Offline maxp
  • J reg 8v digi gti
« on: 19 March 2009, 18:38 »
Seeing as both the tweeters work but neither front speaker works ive figured the best place to start will be from the car stero backwards.
Can anyone recommend where i'd start? Am i gonna have to take the whole dash to get at it properly?
Offline JimR
Re: Best way to attack speaker problem?
« Reply #1 on: 19 March 2009, 18:43 »
Speakers in the door? Do you have a component set up up front (with x-overs) or have i mis-understood and your 'tweeters' are the dash speakers and your 'front speakers' are in the door but wired to the rear speaker output? More info needed amigo.
Mk2 GTi.
Offline maxp
  • J reg 8v digi gti
« Reply #2 on: 19 March 2009, 18:58 »
Sos for my vagueness, i called them tweeters but maybe they arent....anyway i meant the tiny speakers at the far corners of the dashboard.
When i turn the stereo on, the sound only comes out of these, they basically sound like very high pitched, tinny and quite - like headphones so thats why i thought they were tweeters.
Nada coming from either footwell / door speaker
« Last Edit: 19 March 2009, 19:00 by maxp »
Offline Rodriguez
« Reply #3 on: 19 March 2009, 19:08 »
Same problem here. :huh:
Offline muppet
  • 1.8 16v Oak Green :D
« Reply #4 on: 19 March 2009, 22:42 »
could be old and nackered!!! if theyre original speakers and if you doors might have been leaking the speakers in the doors might have rusted connections or maybe even broken off?!?!?! worth taking out to look if you havent already
Offline maxp
  • J reg 8v digi gti
« Reply #5 on: 19 March 2009, 23:48 »
Fair point mate. I tried swapping the speakers over, plus i had a spare knocking around which i tried on each door and no sound out of any of them. Could be terrible luck that all three speakers were broken but i think its unlikely.
Offline drapergti
« Reply #6 on: 20 March 2009, 08:07 »
It depends how the door speakers have been wired in.
Have a look at the dash speakers and see if the wires have been tapped to send a signal to the door speakers, if they are broken it or fallen off this will be the cause.
Alternatively have a look at the back of the headunit, to check for broken / missing connection.
Another possible option is the speaker wires have broken somewhere else like between the door and the frame.
If all else fails and you can identifiy the right wires and insulate them, I would drop in a new cable either from the HU or the dash speakers.
Its a little fiddly but can be done and may be quicker to do, but make sure you insulate the old wires or remove them.
Offline AdamMk2
  • Beautiful
« Reply #7 on: 20 March 2009, 18:04 »
Couple of ways to attack this one lads.
Basically the HU is going to have to come out for a start.
Now you have your original loom im assuming, however over the years maybe things have been altered off of this.
In your original loom is it the plug or have things been bullet connectored off it?
If its bullet connector thats a bonus because fault finding becomes less hassle!
going on Bullet connectored firstly
Check all connections are tight and crips are touching cable not sheath, then move to offending speakers and check there.
Once thats been done if all is sound swap around rear speaker output on the HU loom bullet connectors with the offending front ones and see if it works.
IF SO
there should be a channel down on the HU (Front), they do offer repair services, usually resistors go, but can be quite pricy to have done £80ish is a common charge I believe
IF NOT
check continuity of cabble with a continuity tester (This can be performed by connector blocking both + and - ends of the cable speaker end and one prong each on + and - loom end. tester will buzz if continuity of cable is present.)
If it doesnt buzz and show continuity you have damaged cable somewhere and is adviseable to change if poss  :smiley:
This also means you can repair the cable however it may pay to run newer insulated cable without joins
Hope this helps lads
 :cool:
Ad
Offline maxp
  • J reg 8v digi gti
« Reply #8 on: 20 March 2009, 21:10 »
Thanks mate, mega helpful.
Just a cautious question -  went to remove the stereo and its totally wedged in. It might help to remove the heater control underneath it - i can remove the casing but how do i get the temperature sliders out, can i just yank them?
Offline JimR
« Reply #9 on: 21 March 2009, 08:27 »
Yeah, just grab pinch them and pull them out.
Mk2 GTi.
