Author Topic: Rear Wiper staying on  (Read 2149 times)
Offline Hulmie
  • White MK4 1.8T AGU K03s
« on: 19 March 2009, 07:32 »
On the way to work this morning my front wipers came on without even moving the stalk and stayed on until i went round a left turn, but then my rear wiper came on and has stayed on even though stalk is in the off position.
What could be causing it? Do i need a new wiper stalk?
Offline Rhyso
Re: Rear Wiper staying on
« Reply #1 on: 19 March 2009, 09:21 »
i think Steve_PD had this problem mate
can't remember if he replaced the rear wiper motor and or the wiper relay
Offline Hulmie
« Reply #2 on: 19 March 2009, 13:03 »
Hopefully he'll see this and reply. Just seemed funny the front wipers coming on all of a sudden and then going off when going roud a left bend. May take steering wheel surround off and see if anything on the stalk has snapped.
Offline Hulmie
« Reply #3 on: 19 March 2009, 17:31 »
Well coming home from work neither front or rear wipers played up. But i have yet to turn them on to test them. Will the relay have reset itself once i turned the ignition off?
Offline Steve_PD
« Reply #4 on: 19 March 2009, 18:00 »
Same problem I had, the rear wiper was leaking water onto the multi plug causing a short in the circuit which then caused the front wipers to come on.
check for water around your rear wiper plug. I bought a new wiper (thanks Dave  :wink:) and had no problems since.
Your lucky theres no grit on the roads mine happened in winter and I pulled the fuse so no wipers would work, by the time I got home from work I could barely see out the windscreen because of all the crap  :angry:
Offline golfgtidan
« Reply #5 on: 19 March 2009, 20:42 »
i have this problem with my rear wiper, sometimes it will sweep once and wont again for a few seconds and sometimes it will sweep 3 times or more then wont again for a few seconds... in the end i took the fuse out. ive tested the rear wiper motor and thats fine so it leads me to believe either my relay or switch is at fault...  :rolleyes: just havent bothered fixing it.... yet.
1999 1.8t : Winter Pack : Kamei Mesh Grille : Forge 007p D/V : Carbonio Cold Air Intake : R-tech remap : 18" Toora Alloys : -30mm Eibach Springs : Smoked Side Repeaters : Hella Magic Colours Rear Lights : Hella Black Headlights : "hid" Headlight Conversion : Aero Blades Front & Rear: ECS KVW100 Window Control Module : Milltek resonated cat back
Offline Hulmie
« Reply #6 on: 19 March 2009, 21:57 »
Cheers for that Steve. Funny thing was though that i havent used the rear wash wiper for a while, just flicked the wipers on before i left home and then turned them off ok. was about another 3-4 mins before they came on without touching owt. So not sure how water has leaked, i do know the wash wiper/motor needs replacing due to the shaft being knackered but i know not to use it.
Will have a look at the weekend. Cheers
Offline nerobo
« Reply #7 on: 19 March 2009, 22:10 »
Has anyone had a problem with the washer? As mine isnt working. (I have tryed filling the bottle lol)
Offline richw911
« Reply #8 on: 19 March 2009, 22:11 »
Pipe popped off?  :undecided:
Offline Steve_PD
« Reply #9 on: 19 March 2009, 22:11 »
I never used mine because of the the same reason, then sometimes it would come on, then one day the front wipers come on and wouldn't stop.  the only way they stopped was by taking the fuse out  :sad:
