Author Topic: V12 AMP NO POWER HELP!!!!  (Read 4679 times)
Offline Dizzie
  • Make friends with your fast
Re:V12 AMP NO POWER HELP!!!!
« Reply #10 on: 19 July 2004, 00:11 »
I had a sony amp do that a couple of years back. I sent it off to be repaired under warrenty and I can't remember what they said was wrong. probably a transistor inside popped.
I was running 8AWG cable back then and even that had a 50A fuse on the battery end.
it's probably not worth spending any money on it. you can get better amps cheap online. 2nd hand stuff is always trading hands on talkaudio.com
I bought a Genesis ST100 for ?100 and it's the best little amp I've had. it's only putting out 2x80w or 1x270w, but it powers everything.
Mk4 Golf 150PD
Offline gazzagtiT
  • Houston, we hav a pic here!!
« Reply #11 on: 20 July 2004, 22:45 »
Think its alright now,its working, i connected the earth an remotewithout the fuse in then the fuse then the power cable an hey presto!! But just need to check a few facts, when ive had two amps before i needed two outputs from the head unit, however i only have one amp now but running as a 3 channel, brigded to the sub an then to the rear 6X9's! DO I STILL NEED 2 OUTPUTS FROM THE HEAD UNIT!! oR WILL ONE STILL GET ALL THE TONES TO THE REAR SPEAKERS AN THE BASE TO THE SUB???? ;D
Its all better now very shiny, but now the windows have gone again! and shocks are squeaking like mice!!aarrgghhh
