Author Topic: Why would my golf be sagging on the drivers side? UPDATE  (Read 3476 times)
Offline Llewellyn
I know this is my second post in 10mins, but i was justing comtemplating when my golf is sagging on the drivers side, bearing in mind i have just changed both top mounts.
It is lowered 40mm apparently,  is it likely that the coil spring itself is sagging? (i dont know how long they have been on the car, over 2 years i'd suspect)
James
« Last Edit: 30 March 2009, 11:08 by Llewellyn »
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline Ben Lessani
Re: Why would my golf be sagging on the drivers side?
« Reply #1 on: 18 March 2009, 14:22 »
The spring dictates height - are you sure you seated the spring in the top mount properly when you changed it?
For the springs to change height you'd either have to heat the crap out of them or snap them.
Are the front wheels both the same size?
Offline Llewellyn
« Reply #2 on: 18 March 2009, 14:24 »
Yeap they are definately seated correctly, plus it was sagging before i changed the top mounts.
Both wheels are the same size :)
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline Ben Lessani
« Reply #3 on: 18 March 2009, 14:26 »
How are you comparing the height, from arch > floor or the chassis > floor?
Offline Llewellyn
« Reply #4 on: 18 March 2009, 14:33 »
measured from the floor to arch top.
and also by eye you can see that the splitter is lower on the drivers side
its catching my tyre on the drivers side also
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline Ben Lessani
« Reply #5 on: 18 March 2009, 14:41 »
Pass then.
Either the springs are different or not seated right, or there's something drastically mechanically wrong.
Offline Llewellyn
« Reply #6 on: 18 March 2009, 14:45 »
Had exactly the same problem with my last mk2,
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline Mew
« Reply #7 on: 18 March 2009, 15:16 »
Was that my old one?
If so, that was fine when i had it on Boge shocks and Spax springs...
Offline Llewellyn
« Reply #8 on: 18 March 2009, 15:18 »
Yeah it was, i only had the problem when i fitted some cheap 35mm drop springs.
She sat nice a true on the Boge and spax setup.
Its been like it since i got this one and its annoying me big time!
Mk2 GTI 16v
Mk2 Scirocco 8v
Offline Mew
« Reply #9 on: 18 March 2009, 15:23 »
I think you need to look at the springs really. They could easily be different eg gti and non gti, lowered and non lowered, different brands etc
I'd look at getting a cheap pair/set of springs and seeing what difference they make
