Author Topic: Question about headgasket  (Read 2819 times)
Offline Scott_150
« on: 17 March 2009, 20:35 »
Hi,
Just a quick question- if a head gasket is done on a mk1 will it have to be re torqued up after X amount of miles?
Cheers,
Offline dan_b998
Re: Question about headgasket
« Reply #1 on: 17 March 2009, 23:17 »
i'm sure theres someone on here who could help u with that aka rubjonny he knows his stuff with the mk1's
a haynes manual could tell u if u have one (if u haven't my advise is buy one)
they come in very handy at times
or u could search it on google
« Reply #2 on: 18 March 2009, 08:49 »
no re-torquing is required on petrol engines :)
« Reply #3 on: 18 March 2009, 12:23 »
As above, only the diesels need retorquing, I would fit new bolts as well however.
Offline Scott_150
« Reply #4 on: 18 March 2009, 20:33 »
Ah thats great! thanks for that mate
Offline Village Idiots
« Reply #5 on: 19 March 2009, 10:47 »
No question about it....definitely new bolts as you stretch them on fitting.
« Reply #6 on: 19 March 2009, 11:00 »
technically on 8vs you can re-use them, its 16v ones that need binning, plus diesels. says so inthe bentley, but for the price of em I'd always buy new either way.
« Reply #7 on: 19 March 2009, 16:52 »
Also worth remembering to blow the headbolt holes out with an air line saves cracking the block.
« Reply #8 on: 20 March 2009, 08:11 »
or if you dont have a fully equipped just clean them out with a rag/tissue ;)
I also got an old bolt and cut 4 grooves down it, to create a makeshift tap :)
