Author Topic: Coilovers - adjusting  (Read 2436 times)
Offline so1o
« on: 17 July 2004, 21:57 »
I picked up my supersport coilovers today and fitted them. How the hell do you know that both the sides are evenly dropped?Same ride height or is it a matter of guessing?
Another thing, my front top mounts were replaced with g60 ones, is there meant to be a gap between the suspension hole and top mount? Either i havent fitted them correctly but i get a banging sound because of the travel, any ideas?
Need to get this sorted asap so any help appreciated.
Solo
Offline AdamB
  • The Perfect Storm
Re:Coilovers - adjusting
« Reply #1 on: 17 July 2004, 22:01 »
Adjust them by eye, then drop the car on the floor, measure the difference in height at the top of the wheel arch, raise the car and adjust to compensate. make sure you mark the height on the thread when finished, then any further adjustments just involve counting the number of turns on the thread.
I don't own this anymore - I just can't be arsed to change the picture
Blue MK2
« Reply #2 on: 18 July 2004, 00:57 »
to solve the gap problem....
use some washers Solo. happend to mine.
Ive got no clue about ride height but i just lowered it by eye and evenly adjusted it on the coilovers.
one other thing..
Did you get the adjusting ratchet thing with the suspension?
I didint so i used an old oil filter ratchet. Saves alot of time ;)
make sure u cover the whole coilover with some protector. I used copper grease :)
« Last Edit: 18 July 2004, 01:00 by Blue MK2 »
Offline so1o
« Reply #3 on: 18 July 2004, 07:51 »
Mine are covered in grease lmao. The top mounts, i dont understand them, mk1's fit snuggly, they fit into the suspension turret... but are mk2 ones meant to have a gap between them and the hole?
Offline so1o
« Reply #4 on: 18 July 2004, 09:28 »
After a bit of reserach the top mounts are meant to fit like that i.e with a gap when the cars on the floor.
Is the supersport meant to be so soft......?
Offline lowgolf
« Reply #5 on: 19 July 2004, 01:30 »
I bought mine second hand now when i want to move them i have to pursuade them round with a hammer and chizel  >:( Might try some copper grease to help them round a bit. Also ive noticed that my fronts are near the bottom or their adjustment whereas the rears are only half way down, but the back sits a bit lower than the front  ???. Ive got AVO's. Anyone esle found this  ???
<br /><br />Yeah!!!
Offline so1o
« Reply #6 on: 19 July 2004, 02:25 »
I cant say as i havent tried them but have heard that they are very hard, could'nt find any in time.
Buy some spray grease, thicker the better, willloosen it up in no time.
Solo
Offline tallchap
« Reply #7 on: 19 July 2004, 13:05 »
Right, setting up coilovers. I do this on race cars (Clio's) so the set-up is slightly more critical, but the basics are the same.
Start with all the platforms at the bottom and adjust from there. Count the number of turns, and make sure each strut has the same amount of turns applied. You will then get a uniform height all round.
Doing it by eye or measuring from wheel arches to tyres isn't very reliable as you are unlikely to have a completely flat floor and body panels, etc are often not straight/level. If you do it by eye you are likely to get very strange corner weights...
Coilovers give you the opportunity to move weight from corner to corner to change the balance, handling and tyre temparatures/wear. As I said at the start it is move critical on race cars but will affect a road car too.
Basically, if you raise the height of the rear right, it will transfer weight onto the front left. This may cause your car to understeer, alot and will make the tyre overheat! Conversely, if you raise the front corners, it will transfer weight onto the opposite rears. This may cause lack of grip at the front in high speed corners, and a serious amount of weight transfer during braking.
If you move each platform an equal amount of turns you shouldn't be too far off. You could get the car professionaly 'corner weighted' on a flat floor to ensure it is all working effectively....
