Author Topic: Brake fluid  (Read 1019 times)
Offline nikkyboy
Brake fluid
« on: 17 March 2009, 16:53 »
My 8v is (finally) getting close to coming out of winter hibernation.  During the winter I dismantled and replaced loads of brake bits, master cylinder, hoses, piston seals, the fluid was drained out.  How much fluid do I buy to refill and bleed it?
Offline Lap
Re: Brake fluid
« Reply #1 on: 17 March 2009, 18:10 »
When I did it last year, I found 2 litres to be enough.
Offline Agreeable Slick
  • Unit
Re: Brake fluid
« Reply #2 on: 17 March 2009, 18:15 »
No more than a couple of litres, but it's better value the more you buy (like most things)
oh and DOT4 incase you are wondering.
Offline nikkyboy
Re: Brake fluid
« Reply #3 on: 17 March 2009, 22:27 »
Great, thanks for your help.  I can make a mess with all that this weekend  :grin:
Must say, I got new piston seals from Biggred's website. At first I ordered the wrong set and didn't realise until weeks later, when I got round to fitting them.  When I contacted them to say they didn't fit, they agreed to exchange no problem and at no extra cost. Only took a day to deliver the first set as well.
Offline danny_p
Re: Brake fluid
« Reply #4 on: 17 March 2009, 23:42 »
i buy 5lts of brake fluid at a time,   one dose the job  but  i quite often undo the bleed valves on the callipers  and let some fresh drain through if they have starterd to feel soft after lots of abuse,  alsp 5ltrs is cheeper than 2x1 ltr in local motorfactor
all the VW's have gone bar 1.
