Author Topic: wiring diagram  (Read 3856 times)
Offline d4ve
wiring diagram
« on: 02 July 2003, 15:32 »
Can any1 help me please. I've got a 1994 8v gti, some little s  :-X  t has broken into my car, and in some strange attempt to hotwire it has cut all the wires to my dash and steering column. Now I could have took this to vw for a hefty sum but my dad rekons he can sort it, all he needs is a wiring diagram. Now firstly is this gonna be possible for him and does anyone have the relevant diagram? Cheers, jenny.  Sorry if anyone has already read this but i thought i may get a better response by putting it here aswell.
Offline modulater
Re:wiring diagram
« Reply #1 on: 07 July 2003, 23:11 »
How are you getting on?
In theory it sounds ok as long as its not a total mess of wires, you should be able to join a lot of them up using the current wire colours you have but will need a diagram when you start getting colours that are the same, namely brown and red "Earth and live) A friend of mine has a VR6 and has most of the manuals going for it so I'll borrow them and scan the diagrams off if you want.
Also remember to use heat shrink tubing and soldered joints as anything else is likely to case a fire, If push comes to shove I wouldn't take it VW but an auto electrician as they are gonna be so much cheaper.
