Author Topic: boot central locking  (Read 4770 times)
Offline sidecarphil
« on: 14 March 2009, 09:09 »
i want to fit a remote centarl locking kit to my golf
i bought a kit with 3 solenoids but how do you fit the solenoid for the boot locking ??
or am i being a comlete fool  ??
Offline Ben Lessani
Re: boot central locking
« Reply #1 on: 14 March 2009, 10:57 »
Your a fool ;)
I'll take a photo of how I did mine for you, its a bit 'different'
Offline sidecarphil
« Reply #2 on: 14 March 2009, 11:22 »
excremant  :grin: :grin:
thank you ben
Offline Ben Lessani
« Reply #3 on: 14 March 2009, 11:58 »
Right, this probably won't be ideal for you, but I fitted this about 3 years ago with whatever I had laying about at the time.
Its worked perfect without fail, but it looks bodgy
Just noticed I've got some nice rot inside the boot lid too - awesome
The rubber bandy bit is to pull the solenoid back to normal position after firing. As I used a spare normal door lock pusher, it doesn't return to centre - hence the rubber band.
The metal wire is just so I could mount the popper transversely, and it takes less effort for it to open because its a 'pully' type system, physicsy stuff and all that.
« Last Edit: 14 March 2009, 12:00 by Ben Lessani »
Offline sidecarphil
« Reply #4 on: 14 March 2009, 14:41 »
is that a "lock " or an "open" soliniod ??
how does it work cos i aint got a clue  :undecided: :undecided: :undecided:
Offline Ben Lessani
« Reply #5 on: 14 March 2009, 16:12 »
Ooookey dokey. What I've done is put a solenoid in the hatch that simply replicates the action of pushing the button on the boot plinth.
But because I disconnected the button's mechanism, you can't open the boot from the outside at all - even if you have the key - pushing the button is futile, its not connected to anything. Mine opens from a spare button on my alarm remote.
If you want to replicate the action of putting the key in the lock and turning it - then I'm not sure how you go about that, as I haven't done it. But if you look at the internals of the boot, it should all be pretty straight forward.
Offline sidecarphil
« Reply #6 on: 14 March 2009, 17:39 »
ok ok i see :)
i was wondering how VW did it :-
A as factory
B how the dealers retro fitted cental locking
as i cannot work it out  :angry: :angry:
Offline Ben Lessani
« Reply #7 on: 14 March 2009, 17:50 »
Hows this ...
I've not got a close-up view, that's the best I've got.
But factory fitted, you still used the button popper, but the solenoid just pulled the mech out the way of the button by the looks of things.
Offline sidecarphil
« Reply #8 on: 14 March 2009, 18:20 »
thats ace its even in my colour  :grin: :grin:
Offline sidecarphil
« Reply #9 on: 15 March 2009, 18:24 »
any one else wanna help ??
bit stumped on it
