Author Topic: Steering wheel play  (Read 855 times)
Breaker
Steering wheel play
« on: 13 March 2009, 22:43 »
I've got some play in my steering wheel column.
This is only slightly and only up and down.
Before I go ripping off the dash to find the play does anyone know what might cause this.
 :smiley:
Offline Gambit
Re: Steering wheel play
« Reply #1 on: 13 March 2009, 22:44 »
its the bearing in the steering column housing
Offline james_16v
  • 1986 Golf GTI 16v
« Reply #2 on: 14 March 2009, 14:44 »
I noticed this on mine a couple of weeks back.
Turned out the allen bolt that holds the steering lock housing to the column was loose, I tightened it up and it sorted it.
Worth a quick look.
« Reply #3 on: 16 March 2009, 08:08 »
I find the column bearing rarely goes, its usually the plastic bush between the column and bearing or the UJ/rack
