Author Topic: 8v to 16v mk2 conversion  (Read 1946 times)
Offline ajgti 16v
« on: 13 March 2009, 22:23 »
HI there ,I have carried out a engine conversion from a 2.0 8v seat engine to a 1.8 16v gti engine
the reason for the conversion was a ecu failure with the 2.0 8v engine which was taken originally out of a 99 seat .
Luckily I had a mk2 16valver in my shead so carried out the conversion a.s.a.p
the loom and all usual was changed by a vw mechanic,the timing belt and service has been done all vaccum pipes have been checked also. the car will turn over but will not pick up power when the boot is put down.I would be very greatfull of any help or ideas that may help .
Thanks  P.S. the engine im using now is a 1988
aj
Offline Adam
Re: 8v to 16v mk2 conversion
« Reply #1 on: 14 March 2009, 00:58 »
EDIT:just re-read it....so my input was useless.
« Last Edit: 14 March 2009, 22:46 by 8v8v »
Down Hill From Here.
Offline danny_p
« Reply #2 on: 14 March 2009, 11:40 »
its timeing related,    probaly spark
all the VW's have gone bar 1.
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« Reply #3 on: 14 March 2009, 19:44 »
did the fuel pump get changed?
« Reply #4 on: 16 March 2009, 08:30 »
^^ very good point, 8v pump & lines are no good for a 16v, pressure not high enough.
Offline ajgti 16v
« Reply #5 on: 16 March 2009, 19:07 »
hi ,cheers for the ideas ,yeah i changed the fuel pump to 16v ,it was the in tank pump .the other pump remains standard,
I beleive the timing was checked .what would the chances be that it is fuel realted?????? thanks
aj
Offline danny_p
« Reply #6 on: 16 March 2009, 23:45 »
ahh,  the lift pump ( in tank is same  8 or 16v  ) the under car pump is massivly diffrent.   8v = 3 bar  16v = 6-7 bar
