Author Topic: New question worth relaying them?  (Read 1597 times)
Josho
« on: 13 March 2009, 21:26 »
See my last post
« Last Edit: 13 March 2009, 22:02 by Josho »
Offline Khare
  • The bear that khares
Re: Hella Twin alignment
« Reply #1 on: 13 March 2009, 21:29 »
thought you where leaving????
Josho
« Reply #2 on: 13 March 2009, 21:30 »
Yes. I am. Just like, really need advice. Sorta overthrows it. I'm a bit.... weak.
Offline Khare
« Reply #3 on: 13 March 2009, 21:34 »
oh ok.
well as far as i know dipped should be same level as headlight, so park up on a flat surface, and the more powerful bit of the pattern should be level with the headlamp. As for the high beam, i set it so its just abit higher than the line of the dipped.
Josho
« Reply #4 on: 13 March 2009, 21:38 »
Cool.
I came into some cash, so HID kit, VR6 genuine spilitter and a GTi grill hopefully.
Josho
Re: Hella Twin alignment New question
« Reply #5 on: 13 March 2009, 22:00 »
Is there any point in relaying HIDs?
I'm going to rewire the Hella high-beam and relay that anyway, but is there any point?
Offline Khare
« Reply #6 on: 13 March 2009, 22:01 »
you cant relay HID's.....
now, relaying STANDARD lights then yes, it does make them bright white rather than dim yellow.
Josho
Re: New question worth relaying them?
« Reply #7 on: 13 March 2009, 22:03 »
I mean, the standard loom just plugs into the ballasts, I was thinking connect the balasts to the battery with a relay.
Offline Khare
« Reply #8 on: 13 March 2009, 22:04 »
why would you relay an 8000K light?  :laugh:
Josho
« Reply #9 on: 13 March 2009, 22:06 »
4300 or 6000.
Because I don't like the thought of that load going through the dash.
