Author Topic: EVOM's vs Dbilas intake noise  (Read 8579 times)
Offline RobGTI
Re: EVOM's vs Dbilas intake noise
« Reply #20 on: 16 March 2009, 19:26 »
Hi Guys,
I run a dibilas intake with forge recirculating valve and it makes a lot of noise on hard acceleration and also on lift off. Like a scream. I am thinking of changing to something quieter to be honest.
Matt
If you change the forge valve for the latest revision G VAG item that scream / screech noise goes away. I found this out by accident when I changed the forge item for a standard item.
Edition 30, Black, 3 dr, Manual, Xenons, Highline, Sunroof, Armrest, Cruise, Touchscreen Nav & Bluetooth.
Offline RedRobin
« Reply #21 on: 16 March 2009, 19:41 »
Hi Guys,
Matt
....Reading that^ is enough to make me want a Dbilas! I've already got the Forge DV.
Offline RobGTI
« Reply #22 on: 17 March 2009, 09:32 »
Its not as bad as described and only occasional when accelerating hard. Believe me its a lot quieter than the EVOMS and I am quite fussy about being subtle.
Offline pazz
« Reply #23 on: 17 March 2009, 12:31 »
As mentioned before, wheres the cheapest/best place to get an EVOMS intake system?
Offline AlanD
  • MK5 2.0T 16v
« Reply #24 on: 17 March 2009, 12:40 »
JKM do it for £310 inc VAT. For the cost and hassle of fitting it (you loose the engine cover unless you chop it) you might be better of getting a Carbonio intake. That is unless you dont mind spending more and fitting it.
Offline pazz
« Reply #25 on: 17 March 2009, 19:03 »
I dont think the fitting will be rocket science. I'm never minded getting my hands dirty in the past.
Offline pazz
« Reply #26 on: 17 March 2009, 19:14 »
I've just read on VWVortex that the EVOM uses plastic pipework? I think for £250+ I could make a better intake kit myself.
Offline ukdub
  • WH05 DUB its my DUB
« Reply #27 on: 23 March 2009, 19:15 »
Hi Guys,
Matt
Funny you should say that.  As it happened the other way around for me.  Went from my standard 'c' DV to the Forge DV and the harmonic noise went away :shocked:
Laser blue with BBS CH wheels in 19"
APR software, APR RSC turbo back exhaust, APR HPFP, Dbilas flowmaster intake, KW V3's
BSH speedshop PCV stage 2 fix but with Forge catch can
Offline winrya
« Reply #28 on: 23 March 2009, 19:21 »
Hi Guys,
Matt
Yep had mine done a couple of months back.  No dumping sounds anymore, actually sounded really nice before, its certainly a noise i miss.  I went from C to G revision
