Golf mk1
noisy petrol pump
Topic: noisy petrol pump (Read 3957 times)
standrews47
Just got here
noisy petrol pump
15 July 2004, 17:50 »
My petrol pump on my MK1 GTI 1985 cabrio is very noisy, anone know anything I can do about it, or do I just need to replace it
Dizzie
Forum addict
Make friends with your fast
Re:noisy petrol pump
15 July 2004, 23:57 »
that's normal
Mk4 Golf 150PD
Dinky
Guest
16 July 2004, 00:38 »
Mine isnt that noisey tbh,if u reckon u have a fault.check it n replace it if need b.Stu does a gud deal!
Dinx
VWnut
GTI forum regular
16 July 2004, 14:20 »
Mine was also very noisy. I had a look under the car and found that if i moved the pump the noise stopped. Turned out that the rubber mounts had worn and the pump had tilted causing the noise.
richandhazel
Global Moderator
Forum addict
17 July 2004, 08:48 »
The pumps also get more noisy as they wear so you may find you'll need to replace it soon.
stubbsy
17 July 2004, 11:35 »
is the noise like a whering sound. if so myn is making the noise realy loud. also my car when i accelerate loses power, the engine is still running but the car starts slowing down and will then gain power again and jump forward. could this be to do with the fuel pump?
MK1_BOY
Here all the time
Low Low bored out MK1 Golf GTI Campaign.
Reply #6 on:
17 July 2004, 19:38 »
Mine was noisy so and had a fuel problem so swapped it out, still had the noise and the problem.... The are noisy, when you twist the ignition once they start up... Its a "reasuring"noise, get used to it!!!!
Race ya...
ronnie'C'
Here all the time
MKVI GTi and a MK3 VR6 (lhd)
Reply #7 on:
02 August 2004, 20:49 »
AAAAAAHHHHHHH, my fuel pump was noisy and it now does not make the noise and along with that the car will not start. Is there a relay I can change or is it fused(have not haynes yet and not owners manual. I am at my wits end with this car and I don't fancy paying nearly ?100 pounds for seeing as I have just bought a new clutch to fit to it. :'(
MK1_BOY
Here all the time
Reply #8 on:
03 August 2004, 13:45 »
Got a multi meter??? Check the conns on the pump to see if there is power coming through, if not go to GSF...
Race ya...
gibby
Forum addict
Champions of Europe,ooh ,just the five times then!
Reply #9 on:
03 August 2004, 13:53 »
Quote from: 79ronnie on 02 August 2004, 20:49
Check the fuel relay switch in the fuse box, if its the same as mine under the passenger kick panel it will be the larger black relay on the top left of the fuse box, take that out and check the connections, if it's worn or it looks like it's burnt out try cleaning the connections and pop it back in as they can build up crap on them if the connection isn't true, if you turn your ignition on and you don't hear the whurring noise from the fuel pump then it's not going to start. My relay played up on me this weekend and VW wanted ?38 for a new one. You should also be able to hear the relay click. Good luck.
......now officially dubless.
Golf mk1
noisy petrol pump
