Author Topic: mk2 running rough  (Read 860 times)
Offline squires
mk2 running rough
« on: 11 March 2009, 23:25 »
my 8v digi has recently been running a bit rough, basicly if i accelerate, and let off the throttle and dont change gear and engine brake it kangero's a bit then goes normal, and the idle has recently been a bit ify, any ideas? i was thinking its the isv but i work 6 day weeks 8 til 6 so need a good idea of what to look out for as il be doin it on my lunch breaks lol
many thanks
lee
Offline Ben Lessani
Re: mk2 running rough
« Reply #1 on: 12 March 2009, 00:36 »
Check your vacuum hoses for leaks, then the overrun cutoff valve.
Offline DarnPB
  • Formerly Darnpistonbroke
« Reply #2 on: 12 March 2009, 08:26 »
The first thing I would check is the timing. It sounds as if it could be a little retarded.
Offline squires
« Reply #3 on: 12 March 2009, 20:11 »
its only started doin it recently, had more toruble today, whenever i got stuck in stop start traffic the main fuel pump starts buzzing then it missfires and cuts out,its always been a bit ify wen the gaugue is low on fuel so im gna do the lift pump first, looks like iv got a busy weekend :sad:cheers for the replies
Offline Ben Lessani
« Reply #4 on: 12 March 2009, 20:41 »
^^ Replace the fuel filter and clean the mesh filter in tank.
Offline DarnPB
« Reply #5 on: 12 March 2009, 20:47 »
I would not go for the complcated things yet. Do the things you can get at and go through a process of elimination or you could be wasting loads of time with no reward.
