Author Topic: mk3 aniversary clocks (not just the dials , the whole unit)...  (Read 2701 times)
Offline joff GTI
i`ve found some but the mileage is 70k & my original clocks are 119k , is there any way this can be adjusted from 70 to 119k to match what mileage my car actually is? also will it be difficult to fit?
kells
can be done, will cost about 30 quid, you need to call one of those electronic dash people you see advertised in the auto trader, i did the same with the same clocks
Offline joff GTI
cool , did you instll them yourself?
Offline cabbydub
its easy mate, about 6 screw, 2 on the steering colum surround (so it splits) pop out the head lite switch there  one behind it then on the other side remove the blank these two remove the dial surround then there is two holding the dials in remove these, once removed pull the clocks out so you can removed the connector, the fit the new clocks
Offline boneybradley
  • Back in a Mk3...
just ensure they are genuine anni clocks!! I have seen some on ebay that arn't!! (the tell tale should be a fuel light..as the anni didn't have this)
Offline Khare
  • The bear that khares
gti's dont have fuel lights either do they?
Josho
Anni didn't have a fuel light? Odd isn't it?
Anyway, you can buy a VAG-Tacho off eBay for £20 and do it yourself. Then sell it on.
kells
yeah course, 5 min job, mine are modded to hell, obviously you dont know about me haha :evil:
Offline joff GTI
mine doesn`t , was suprised tho cos i thought most cars had a fuel light...
Josho
Actually, come to think of it, I don't think mine does either.
