Author Topic: Throttle body clean - update!  (Read 1782 times)
Offline Pete H
« on: 11 March 2009, 17:33 »
Ok, i did the throttle body clean on my agu turbo, because the revs would flutuate when i pulled up to a junction, below 1k fluctuation.
Now ive done it, the revs seem to sit higher, ie above 1k, will go down to normal tick over (900rpm) if left long enough, is this normal?
Will the car learn again, as i only did it a couple of days ago and onky driven about 4 times.
cheers
Offline bobbarley
  • I'm kind of a big deal...
Re: Throttle body clean - update!
« Reply #1 on: 11 March 2009, 17:35 »
Yeah it'll sort itself out :afro:
Offline Pete H
« Reply #2 on: 11 March 2009, 17:38 »
good good, it's like the anti-stall things, when you change gear, the revs stay high for a few secs,so if you change quick the car lurches forward sorta thing.
Offline bobbarley
« Reply #3 on: 11 March 2009, 17:39 »
Weirdly after cleaning mine it was spot on straight away  :drool:
Offline dubcruiser
  • Audi A3 SB S-Line 2.0T Quattro 2007
« Reply #4 on: 11 March 2009, 20:07 »
I did mine and it was fine, but before I started the engine after putting it all back together, I turned the ignition on (so the lights on the dash light up) and left it for 30 odd seconds. This lets the sensors in the throttle body adjust and reset. You know its when its stopped doing its thing as the high pitched squeal stops..
Scott
Golf GTi 180bhp 6 Speed 2003, Tornado Red, Electric Sunroof, Climatronic, Winter Pack, Black Leather, Santa Monica Alloys, Centre Arm Rest, 6 Disc Changer, R-Tech Remap (Now Sold)
Audi A3 Sportback S-Line 2.0T Quattro 2007, Lava Grey, Exclusive Line Black/Silver Leather, Heated Seats, Bose, RNS-e, Auto Lights, Auto Wipers, iPod Prep, Interior Light Pack
Offline rheady
« Reply #5 on: 11 March 2009, 20:48 »
Yeah did mine the other day, coud'nt bellieve how dirty it was. Just turned ignition on and left it a bit the started the car. All seems fine. Did disconnect the battery though.
Offline Pete H
« Reply #6 on: 11 March 2009, 21:32 »
cheers lads, tried the 30 sec thing and hasnt worked, maybe ill disconnect the batt at the weekend.
Offline ben1.8T
« Reply #7 on: 12 March 2009, 08:12 »
I took mine off a couple of weeks ago to clean it and it was alreday nice and clean in there perhaps they done it on the last service?
Golf SOLD. Replaced with a Yamaha Raptor 660 quad and loving it. This will be replaced in August with a Raptor 700. Sold the quad now got a Vectra GSI 2.5 V6 and its the nuts.
Brands Hatch massive. MEMBERSHIP ACCEPTED!
Offline saalro
« Reply #8 on: 12 March 2009, 10:44 »
My 1.8T sits at about 1400RPM when cold and goes down to 900ish after a minute or so depending how cold it is. If the car is warn it will sit at 900RPM straight away.
How long does yours take?
Offline Pete H
« Reply #9 on: 12 March 2009, 10:47 »
quite a while, not as quick as i imagine it would, even when warm it takes a good 5secs to drop down to 900rpm :undecided:
