Author Topic: Lowering decision, 60/40 or 40/40  (Read 5656 times)
Offline GOLF_MK
« on: 11 March 2009, 09:56 »
I've got up to £200 to spend on a lowering kit - i can predict now that 90% of you will say get hot tuning coilies but i don't want them, don't have the time to bugger around getting the height the same each side etc etc..  I just want to fit a kit and get on with the rest of my life!!
So i'm looking at fixed spring and shock kits on both Ebay (Jamex) and the few that Venom do online.
Now the standard Mk3 front end looks ridiculously high so i'm not sure if i should go for a 40/40ish kit or go for a 60/40 to make sure the front comes down.
BUT - would 60 on the front be too much for a daily car?  Is it going to cause me lots of grounding issues as i'd rather have the front a bit higher if that's the case!!
Also any recommendations; Jamex, Pi, Supersport, Venoms own - or other??
« Last Edit: 11 March 2009, 10:17 by GOLF_MK »
Re: Lowering decision, 60/40 or 40/40
« Reply #1 on: 11 March 2009, 10:05 »
Go for a 60/40 drop gives a much better stance and you will not have any issues mine was a lot lower than that on the front.
The kits from Venom will be fine.
Offline GOLF_MK
« Reply #2 on: 11 March 2009, 10:18 »
Thanks Wayned, didn't think 60 would be to much of an issue as people seem to run a lot lower but want to be sure!
Offline GOLF_MK
« Reply #3 on: 11 March 2009, 10:20 »
Looks like Venom do 60/60 but not 60/40  :undecided:
« Reply #4 on: 11 March 2009, 10:29 »
Mine was 85 drop on the front with no real problems use to catch the spoiler on speed bumps but thats it to be honest.
« Reply #5 on: 11 March 2009, 10:29 »
I am sure Venom do a 60/40 kit.
Offline Len
« Reply #6 on: 11 March 2009, 10:48 »
You shouldnt have any problems with a 60 drop at the front! Unless you are using very wide tyres!
Just do one thing though! Once fitted go to a good place and get the steering geometry checked and adjusted. Not just tracking but camber and toe as well.
www.sas.org.uk
www.the-ace.org.uk
Offline VR6-Joe
« Reply #7 on: 11 March 2009, 12:45 »
I got a 60/40 supersport kit off egay for my old car
No complaints whatsoever, was actually one of the most comfortable kits I've ever owned
Gone but not forgotten;
1983 Mk1 Golf GX - 1991 Mk2 Golf GTI - 1988 Scirocco Scala - 1989 Mk2 Golf CL - 1993 Mk3 Golf Ryder - 1996 Mk3 Golf SE - 1996 Mk3 Golf CL - 1995 Mk3 Golf GTI 16v - 1996 Mk3 Golf VR6 Highline - 2003 Saxo VTR - 1996 Mk3 Golf VR6
Offline GOLF_MK
« Reply #8 on: 11 March 2009, 12:49 »
Sounds promising!
Offline Dec
« Reply #9 on: 11 March 2009, 12:58 »
9x16 wheels all round. Pictures say it all ;)
